Hi all, well it looks like I might have found the issue with my brakes needing pumping up after replacing rear brake pipes and lines when I had the gearbox out.
One of the bleed valves in the nearside rear (left) caliper has stripped the threads in the caliper. It was a pain to undo and the valve was blocked until I threaded some lockwire through the holes to clear it.
It wouldn't torque up and on undoing it, the remains of the ally thread were wrapped around it.
The plan now, is to try to Helicoil the M10 x 1.0 thread with a Helicoil repair, but this will be tricky as the bottom of the hole is slanted to the shape of the bottom of the valve, so I need to keep the drill well away from this.
If all else fails, it's the black calipers from a 98 C2 and they're around £600 new. Does anyone have any other ideas for second hand replacements, as Ebay isn't throwing up any of the Black C2 ones from that era. Part number 99635242103?
Cheers.
Cheers.
