Tiger911 said:Small update: The Porsche dealership I bought the car from are not accepting what Porsche West London are saying, and they want to do their own inspection. I asked for a full refund as the car is basically a write off, but they are saying they need to check I did not drive into excessive water! ......
Tiger911 said:Small update: The Porsche dealership I bought the car from are not accepting what Porsche West London are saying, and they want to do their own inspection. I asked for a full refund as the car is basically a write off, but they are saying they need to check I did not drive into excessive water! They actually think I went into a puddle which could have caused this. Shocked at the minute and currently in no mans land.
deMort said:Tiger911 said:Small update: The Porsche dealership I bought the car from are not accepting what Porsche West London are saying, and they want to do their own inspection. I asked for a full refund as the car is basically a write off, but they are saying they need to check I did not drive into excessive water! They actually think I went into a puddle which could have caused this. Shocked at the minute and currently in no mans land.
When i was working at an OPC about 6-7 years ago i had a 991 with a flooded out passenger side ( non cab ) .. it was a struggle to find the water leak but it was base grommets not draining out the water ..
I still remember saying to the forman .. with every Porsche so far we start from the top down when trying to find a leak issue ...
With these we have to start from the bottom up .
A correct water test .. carpets and panels inside are removed .. you then water test it .. 5 mins is not enough .. 20 mins min .. a slow water leak with poor drainage will slowly fill the side panels with water .. this to me is the issue here .
Car is not a write off though .. it has a water leak .. some control units under the passenger seat have got wet and must be replaced .. the wiring itself .. very rare that it cant be cleaned up on the connections and be perfectly fine ..
There are control units under the drivers seat but these will stop the car from running if wet.
Talking from many years of water leak experience here from Boxsters onwards .
In short .. fix the water leak and its fine .. up to you if you want to back the car .. i can only say what damage there will be and what the likely cause is .
EDIT ...
Ask them to explain how water got into the car from driving through a puddle .. i'm happy to pick holes in any explanation they can come up with .
