2006 Porsche C4S Twitchy/Unstable at high (motorway) speeds
Book yourself into Centre Gravity for one of their health checks. They will sort it out very quickly. There are a LOT of adjustments you can make to these cars, and if they are mis adjusted, they can feel downright lethal to drive. If you have any suspension issues, they will be found out. Don't go to an OPC, their "OE settings", can be ok, but the car still be all over the road, these cars need a specialist set up.
Thanks! I'm booked in for Wednesday... noob question but what's an 'OPC'?
I would be doing as suggested and seeing what centre gravity had to say as what you describing is not how it should be, is it all stock no added spoilers etc as when I had my front aero kit bumper and lip on but not the aero kit rear spoiler as it was getting painted , the car was exactly how you described.
:thumb: :grin:
Car is completely stock with no added bits so not sure why this happening. I'm hoping centre gravity can get to the bottom of this and perhaps something is loose or needs adjusting.
Hoping and praying it's not anything serious!!
Official Porsche Centre :thumb:
ps. :welcome: to 911uk
Thanks mate!
Just had the guys over at Jaz Porsche test drive and they've assured me car is spot on.... I guess this must just be me needing to get used to the Physics of the car!
Thanks for the speedy responses!
Cheers,
Sanj
Interesting read I have sent a PM to Piranha to find out the outcome on his problem.
I have to say that having a 996 GT3 the front also feels a little light at speed but put this down to the type of car it is. Mine is set up for fast road/track so that probably exacerbates the feeling.
I think coming from any other car the Porsche is bound to feel very different at speed and more communicative. Not sure how much difference there is with a 997 although obviously there are a few more aids.
Pip
I had the pleasure of spending a day under the car on the ramp at Centre Gravity recently and they measure everything. Porsches settle, especially at the front which results in toe out and lots of camber. Great for cornering but twitchy as hell if there's even a slight rut to follow in a straight line as the front wheels are effectively hunting for anywhere else to go I.e. Not straight on...
Mine has dropped 18mm on the front so its now GT2 height. It had also destroyed one bump stop. They straightened the wheels and had a play with the camber. Different car... I don't know how good all the various machines are but the guys' in CofG definitely does the trick.
They're good guys too. Very informative.
Recommend a visit
fixed?
Did you get it sorted Piranha?
have just bought a 997.2 C4S and have very similar issue, apart from mine starts around 70mph.
Yet to check everything suggested here, but if you found a fix it would be great to hear it please.
911s tend to droop at the rear, which changes the angle of the car. Mine was light at the front at motorway speeds. Some shim plates in the rear later and the angle of the car was right and the problem solved.
I'd say that (assuming it isn't a rogue tyre or busted spring/mount or some such), it's the set up. You may need more rake from front to rear.
An old thread I know but was there an update on what it was. Mine is the same. Going to check suspension mounts first then other suggested areas before the long haul to Centre Gravity.
Nope, he posted 4 times in one day and then disappeared. :?
It'll be interesting to hear what CG find with yours. :thumb:
Hoping I find something myself to save the long trip! Will post my findings.
I had these symptoms when I bought mine (from a well known Indy).
An unnerving rear end instability at speed.
Went to CG for investigation. Here's what they found:
124,629
1,442,272
49,073
Ors97
