Wishbones ( coffin arms ) etc
So my top mount was seized to the piston. In the end I drilled the rubber to separate the main parts of the mount which just left me with the bushing on top. I had split it open by cutting it. There wasn't any evidence of rust, so it was just jammed on by interference fit it looks like.
Anyway - what should have been a quick job, turned into an ordeal - but it is sorted now and ready to go back in.
The RH coffin arm ball joint - that was an even bigger ordeal. I took hours as I didn't want to use excessive heat or force. The metal seat came off of the wheel carrier casting - and it still took a few hours including putting the whole arm in the freezer over night, and more gentle heat, and one of my ball joint scissor splitters broke, and then more heat and more leaving it for a few hours under tension, and eventually a few whacks and it popped off. Then Back in the freezer over night. I heated the casing with an electric heat gun - got it up to 90c (measured using laser thermometer) and then very quickly stuck frozen metal seat back on and a few gentle taps and it was seated again. It was one of those jobs that had all the potential to go wrong...
So, while changing arms is DIY for the most part, if it gets hairy, it helps to have good mechanical knowledge and tools and time...
Seat stuck on ball joint
So there I was tonight - got my LH spring/ damper assembly back into the car with a new Hamburg top mount ( the stud snapped on the original one during alignment last year). I just barely nipped up the 3 nuts on the top mount. I then fitted the new coffin and diagonal arms, jacked up the hub assembly so the weight was on the strut and the suspension was at ride height, torqued up the bolts. I was delighted with the progress. I was about to put the wheel on and I remembered I hadn't torqued the mount nuts, so got out the torque meter, tightened them up, outer 2 first and then before the inner even got to the torque, the stud snapped :sad:
I would like to say I couldn't believe it, but based on my experience so far changing the suspension arms, it is par for the course...I'm just miffed hat I may be out of pocket. I emailed Design911 and explained. Hopefully they will sort me out with a new one...
Just when I thought I was going to be going for alignment on Friday... :frustrated:
Has anyone else had studs shear on Hamburg mounts?
Design911 are sending out a replacement part. No quibble. Fantastic customer service experience. :thumbs:
Dont take this the wrong way as Im sure you're a competent mechanic - could you have looked up the torque in Nm and set it as ft lbs?
I have to stick my glasses on now when setting the wrench to ensure I get the right scale!
Ian
new parts
Evening
I ordered new coffin arms from design 911, 1st one came in a sealed box & the other came in a ripped box with broken seal, plastic covering ripped open & dirty hand prints on the metal so in my books this is not a new part. phoned design 911 on Monday & the guy sounded very uninterested just said take photos & email over. not had a chance to do it but I thought they may have said sorry it should never have been sent out like that & if you return to us we will forward a new sealed unit. am I being fussy?
Ian
No! It was the last of the 3 nuts
Re: new parts
PDCC4S said:
Evening
I sent an email with photos and then followed up with a call - so I probably avoided the grief you felt. Regardless, You seem to have had a different experience to me and probably comes down to the individual you dealt with.
Same happened to me couple of years ago.
I was desperate so I drilled the stud out and secured with a nut and bolt. Within 6 months the rubber mount on BOTH sides had separated. Design 911 claimed they had never ever heard of it happening. Yeah, right.
I eventually got a refund from them. Those were the last parts I ever bought from Design911, I find them overpriced for just about everything.
I fitted SACHS top mounts from autodoc.co.uk, cheaper (£20 each) than design911 and they are the genuine part supplier, identical to those from the OPC.
Hi Wazz,
The Sachs top mounts aren't avaiable for the C4S - I did a lot of checking prior to buying and the Hamburg ones got good reviews
I'll just have to see how it goes. I'm going to Video myself torquing the new one in case similar happens.
Sorry for a bit of a thread hijack but does anyone know where to get rear top mounts for a 3.4 c2 from? The tip for autodoc for the fronts was great but can't find rears for anything under the 72quid each for hambergs from d911 which seems a little excessive?
hmmm. Mine were in good nick at ~110k so I reused them.
Usually its the parts shared with Boxster that are cheap (fronts, arms etc), anything 911 specific and you struggle to get aftermarket parts as they don't sell so many.
On Design911 £72 becomes £95 with Vat and delivery.
Same Hamburg part here for £85:
https://www.ebay.co.uk/itm/HT-Stutz...ts-links-passend-fur-Porsche-996/172957715691
Pair £160
https://www.ebay.co.uk/itm/HT-Stutz...ts-links-passend-fur-Porsche-996/362372513229
Not sure on delivery costs.
Do they need replacing? They were about the only part I didn't replace, CG advised they are expensive and rarely fail along with the rear upper arms.....
For the arms, they also said their experience suggests that aftermarket parts are not good enough and the Porsche parts are expensive.
124,625
1,442,225
49,066
Mike 964 speedster
