Wing mirror motor not working properly
ualla
16 Jul 2016
100
Hi all! I wanted to run something by you.
Since I bought my 996, the passenger side electric motor wasn't working properly. Pressing down would make the mirror slowly go down, but the other directions simply wouldn't work. I blamed the motor.
I recently bought a brand new OEM motor and replaced it, but the results are exactly the same as before. In fact, the motor I removed was a non OEM one so previous owner obviously drew the same conclusions as me.
Now before I start taking off the door card etc, does anybody have an idea of what could be causing the problem?
Thanks!
This is really something i would need to have booked in at work to diagnose .. but always happy to have a wild stab in the dark !
The dirvers side works fine i take it and as 1 function works on the passengers side then the change over switch is fine .. therefore its a wiring fault.
Assumeing theres nothing wrong with the plug wiring to the mirror then i would go for a broken wire in the door harness or possibly a high resistance but i would start with checking the wiring for it .
Thanks Demort! I always appreciate your stabs in the dark, they are usually pretty accurate :)
I can confirm that the driver's side wing mirror works perfectly fine and so does the switch over. My assumption was wiring as well, hence why I was going to remove the door card to have a look.
Thank you!!
This was one of the first things that went haywire when my ignition switch was on the way out. if the door wiring doesn't fix it , you may be worth while checking the ignition switch.
Oh wow, that's interesting. Would never have connected the 2. Thanks for the heads up!
infrasilver said:
Mine only worked up and down but not left and right a while ago, I traced it to a dodgy wire in the plug behind the interior triangle panel and I had to re-terminate the plug wire.
Ah cool, thanks infrasilver! seems like a similar problem to mine, I'll look there first.
Cheers guys
124,626
1,442,198
49,057
VeeRacer
