Well specifically the airflow through the center vents. Mine is fine through one side and weak on the other, much to my bemusement as there is nothing obvious causing this.
Browsing on Rennlist where a chap had removed his vent and found there was little to nothing left of the foam seal where it meets the internal system. This would explain the imbalance between the two vents. A simple fix to improve your ventilation :thumb:
