Three issues all seemed to develop with my C4 at the same time and I wondered if they could be connected somehow:
The speedo seems to function intermittently, either completely dead with the needle on "0" but from time to time springs back to life but then dies again. It was sent away for a repair by Porche Torque at the last service to fix the odometer, but that was last September and has worked perfectly until now.
the spoiler operation is also intermittent, it was stuck in in the up position for a bit (not responding to the switch either) then stuck down, but at times seems to work normally (both with the switch and automatically). I assume it's linked to the speedo issue, but the two faults not don't always seem to happen at the same time!
I have both abs and abd lights now showing. Maybe this is just a coincidence?
I have checked the fuzes but just wondered if anyone had experienced anything similar or if there is anything else obvious I should check.
Thank you
Johnny
Thank you
Johnny
