Heuer said:It is the oil circulating but should not happen.. The cure is to always use Mobil 1 per Porsche recommendation and nothing else. Happened to me many years ago and I found out the Porsche specialist was using some other bulk oil and filled the car at service. They were perplexed about what was happening but changed the oil as per my suggestion and the issue went away. They now only use Mobil 1 on all their cars
Did you change the oil - could be a clue? As regards what your car was originally filled with I have no idea. I still have the Mobil 1 sticker on mine so got them to drain whatever they used at service and filled with that. I can only say that filling my car with Mobil 1 immediately solved the gurgling and it has never recurred, others experience may be different.Ben S said:Recently had the engine out and it never seemed to do it before.
Heuer said:Did you change the oil - could be a clue? As regards what your car was originally filled with I have no idea. I still have the Mobil 1 sticker on mine so got them to drain whatever they used at service and filled with that. I can only say that filling my car with Mobil 1 immediately solved the gurgling and it has never recurred, others experience may be different.Ben S said:Recently had the engine out and it never seemed to do it before.
Porsche's lists with EU or WW A40 approval oils appear in Technical Bulletin 1701, and they are all synthetic and include:
Castrol Syntec 5W-50 (G)
Mobil Mobil 1 0W-40, 5W-40 (GL)
Sunoco Synturo Gold 5W-40 (GL)
Havoline Formula 3 Synthetic 5W-40 (GL)
Valvoline high performance synthetic 5W-30 (GL)(GL)
Maybe other oils would achieve the same but I have no interest in researching the issue further - my problem has gone. To quote one of the PCA guru's "For most purposes, Porsche's factory fill of 0W-40 Mobil 1 is the best all-around thing going."
David
ToreB said:I also hear the gurgling from time to time at cold start.
It is a quite unnerving sound, and may even resemble a failing ball bearing or something. I am especially wary for sounds after a major engine overhaul, but my local Porsche Classic workshop has told me to relax and enjoy the sound of oil flowing in the oil cooler pipes.
Cheers,
Tore
