My impression of this fault and smoking in general ..
The Boxer design of the engine .. its flat or Horizontal .. this does allow oil a chance to get into a cylinder where as a vertical engine and the oil drains downwards .
Smoke colour .. basic rule of thumb ..
White .. water based
Grey / blue .. oil based
Black or a very dark colour being over fueling or unburnt fuel .. a rich mixture .
A problem with either of these tends to be a more constant or more occurring problem ..
IE .. 1 min of smoking of any colour or indeed a constant smoking would indicate something is getting into the exhaust .. usually by means of the cylinders but a cracked head can in very rare circumstances allow water into the exhaust direct .. either way it needs to be something continually causing the issue .
Puff of smoke for 10 seconds or less is kinda normal at times based on temperature , how long its been standing .. how its previously been driven etc etc .
valve seals .. well the design with them being at 90 degrees would tend to make oil run away from the seals .. a vertical engine and yup oil can bypass them ..
Oil will sit in the inlet manifold as normal .. i've seen it many times on the Boxer engine .
Bore score will certainly allow more oil into a cylinder due to the design .. its horizontal .
AOS failure .. this tends to be a constant smoking but as the DFi engine has a different design then it's not very common to get one fail .. it does happen but most tend to be the restrictive type whereby it causes a vacuum noise and not smoking .
For me ..
The OP,s video and it looks like white smoke .. that indicates water .. due to the design i will add a bit of oil but on its own oil of a small quantity will give very little colour of normal oil usage .
My thinking is condensation .. a bit of oil and its normal .
For there to be an issue then the smoking needs to be more constant .. something whether it's oil or water needs to be replacing what's just been burnt to keep the smoking going .. that is an issue which i don't see here .
I spoke to the OP via email and suggested if he was worried then a bore scope test .. do it after a night standing and the mechanic will see not only any scoring but oil in any cylinder ..
It would also show any coolant .
In this case it's been 4K miles with no change or drop in levels .. it's also been into another garage who cleaned out oil in the inlet tract ..
Faults get worse as time goes by .
This is just my thoughts though .. i welcome anything to say im not correct as to be honest guys ..
I may do this for a living but i certainly don't know everything and im always open to learning things ..
Constructive criticism is always welcome as i can only ever post what i think .
Thank you for those of you who read this entire ramble
