Slow Cranking
Aghh ok so this is not necessarily a slow crank but a possible slow to fire up .
If you can .. do a sound clip or a video please so i can confirm if its poor start or slow cranking .. i dont really want to tell you to replace a starter motor when the fault is actually something else .
2 seconds sounds about right but a video will tell me a lot .
Bear in mind when i normally fix cars i have them in front of me :D
Really appreciate that deMort, cheers pal.
Unfortunately I won't have access to the car for a while now so can I post back in a week or two :thumb:
There doesn't seem to be a lot of diagnosis going on here. You have a volt meter, have you looked at the following during cranking:
Battery voltage
Voltage between battery - and starter motor -
Voltage between battery + and starter motor +
I would do it by pulling the fuel pump fuse so that I can run it for a good few seconds to get readings. All of this talk of issues with earth or power straps could be confirmed by the above tests. If you are getting a good battery voltage and that voltage is present at the starter motor then it is a motor fault.
If you are seeing significant voltage drops on either the - or the + side then you can further check, such as the voltage from the chassis to the battery - terminal.
I know that slow starter motors are an issue on some models of BMW, so it isn't unheard of.
I've just got round to fixing mine properly. I decided to change the alternator to starter cable, which also carries the starter solenoid feed. i was getting some clicking from the solenoid so it pointed to this. It was pretty green and corroded looking. I put a new starter in for good measure, and it now cranks very quickly, hot or cold.
M
124,629
1,442,273
49,073
Ors97
