Ekona said:They just use different additives, that's all. There is zero issue using supermarket fuel, as it all comes from the same local depot anyway.
John H said:You do know that supermarket fuel doesn't contain the additives that branded fuel does don't you?...
Martian said:HarryH said:Martian said:chimp911 said:...there is a way to force a quick reset but I'm not sure of the exact sequence though I'm sure others will be along with the answer....
Just disconnect the negative terminal from the battery for about an hour.
not forgetting (IIRC) to put the key in and turn to position 1 first, to avoid the alarm going off when you disconnect
Yes, good point. You only ever disconnect the battery without first turning the key once!
Martian said:John H said:You do know that supermarket fuel doesn't contain the additives that branded fuel does don't you?...
:floor:
Another myth.
Next you'll be stating that your Insurance wouldn't pay out if you don't have 'N' rated tyres.
