A few updates before the weekend kicks in.
I have been struggling with the front tunk. I get everything lined up nicely and once I fit the huge springs that open it, it shifts the trunk lid to one side and there isn't enough adjustment in the hinges to compensate.
So I have taken it off and removed the hinges. These appear to be the culprit. They are a flat face fit controlled by the shoulder bolts. Over the years it's all got a bit slack.
So an idea popped into my noodle. If I grab a bit off a CNC milling machine I should be able to machine the worn face flat then add a shim to try and get them tight again.
Only took .3mm off and added a shim. Just got to give it a try now but trying to waggle the longer arm of the hinge now is as tight as a Tit mouses ear. So hopefully fixed....we will see.
Next little project that I have been putting off is the heater controls into the dashboard. The original although all together had been butchered.
As you can see, someone had a good go with there paints!
First off I covered the 'Text' as this is a printed and glued in strip.
I then used patients and a lot of superglue remover to soften the glus at the back of the lit lozenges to get them out. It did work but took a few attempts.
Above picture shows that the surface isn't so flat. My logic was this. If I get it flat then paint it. A light coat of lacquer, mask off and paint the recessed control indicators. Then I could sand back any overspray without effecting the silver. Then fit the lozenges back in and lacquer again to finish. After lightly sanding the top of the text on the lozenges to expose the plastic so the light from the bulbs would show through I finished with this...
So I finished, however all did not go exactly to plan. I had a reaction with the superglue on the lacquered surface.
Also the more I looked at it the more I didn't like the silver. It just looked a bit too much like Aluminum. So more superglue remover and I did the whole job again. This time I mixed a little more blue into the silver and ended up with this (below). I just need to glue the lozenges in, but this time I have left it a week for the paint to really harden. I am hoping this will be the last time I do this...
So hopefully this saga is finished and I can move onto the Targa top for refurbishing. Let's see eh!
