HI all and firstly sorry if I'm repeating lots of questions and i hope not to upset people with this newbie questions.
Just came back from looking at a 91 C2 and would like to ask a couple of questions.
The onboard computer stalk on the steering arm is very loose, meaning there feels like there is no resistance when moving it up. It does work though.
Is this normal for that control?
After the car had been driven and stopped there was a sound coming from the dash area that sounded a bit like a clock that was stuck. After some Secs/mins is stopped?
Normal or not?
There a couple of buttons I have no idea what they do. One is push switch to the right of the ignition (see picture)
Driver door hinge pins have gone. Are they expensive to replace, DIY job or Garage?
It has some nematic controls on the side of the driver seat to pump it up in the back area? I haven't seen pictures of this before. Was it an optional extra or after market add-on? (See attached)
Slight wobble at lower speeds from the steering wheel. Other than wheel balancing (it just had new tyres fitted) is there any common known issues that it could be?
Oil gauges seem to work correctly but the oil level gauge was right at the top and dropped a little when driven. He told me that he had just changed the oil and oil filter.
What should the dial be showing if correct or is this correct? I did read some articles and I got the impression it should be in the middle?
If too much oil how easy is it to drain some?
I tried to see if it had the distributor vent kit but I couldn't see anything that looked like the pictures I have seen on the net. (See attached)
Engine has 200,000 Km and wondered could there be problems with the belt now?
The windscreen has a wire strip in the center of the screen, is this the original antenna for the radio as it has one on the roof?
One thing I did note was that from the engine bay the rocker covers seemed clean and no oil around them. Good sign or Normal?
Thanks for all your help.
Normal or not?
