AVI_8
- Joined
- 19 Jan 2014
- Messages
- 155
I have not found that to be the case, it’s common on steel framed buildings, the timbers on mine are 7 cm thick, having 18 air vents possibly help though which was a requirement from building control, I’ve a digital humidity meter in the garage and it’s generally showing the same RH as outside, there’s never been any visible moisture on the walls, sometimes on the concrete floor when it’s very wet outside.Only problem with timber is the sweating and humidity levels, not ideal for car storage
