poppopbangbang
Nurburgring
- Joined
- 25 May 2015
- Messages
- 480
I have a brand new Enclosed SDL3 available. These used to be our go to for logging on F1s going to teams who would run them themselves as they are bulletproof, capable and everyone can use Motec! We've gone away from them now as the later ECUs we are using integrate the logger but if anyone has a race car on a Motec dash and needs more expansion or has a track car and wants something pretty much top draw then this would be perfect. This has been a boxed spare and has never been on a car, just on the shelf in case required.
Current retail is £3000+ VAT from M-Cal (http://www.m-cal.com/Products/MC35-318019/MoTeC-ESDL3-Enclosed-Sport-Dash-Logger).
This ones available for £1500 Incl VAT
Manual from Motec: http://www.motec.com/filedownload.php/SDL3 User Manual.pdf?docid=3619
Brief Spec:
Logging
-STD 16 MB or optional 120 MB logging memory
-Logging rates up to 500 samples per second
-Fast Ethernet download
Inputs
-8 x Analogue voltage inputs, 4 x high resolution inputs
-4 x Analogue temperature inputs
-2 x Digital inputs
-4 x Speed inputs with voltage measuring capability
-Compatible with up to two E888 expanders (8 Thermocouples only)
Outputs
-4 x PWM or digital outputs
Internal Sensors
-3-axis G sensor
-Logger temperature sensor
-Sensor supply voltage
-Battery voltage
Communications
-2 x CAN with individually programmable CAN bus speeds
Maximum data range 1 Mbit/sec
Recommended terminating impedance 100 ohm
-1 x RS232
Physical
-Dimensions 180 x 91 x 18 mm excluding connector
-Weight 385 g
-1 x 37 pin Autosport connector
It has user configurable strategies and conditions so can be used as a control system if required for fuel pump, cooling, boost etc. etc. really anything you can come up with a table/condition for
Brief Spec:
Logging
Inputs
-2 x Digital inputs
Outputs
Internal Sensors
-3-axis G sensor
-Battery voltage
Communications
-1 x RS232
Physical
-Weight 385 g
