I have just had a fantastic driving day with CATDT (more of that later) any way on the drive back home I got stuck in nose to tail traffic. While edging forward a loud metallic rattling / clanking started from the engine. It sounded like a tin can had gut stuck and was rattling around. I looked underneath but no obvious sign of anything and noise had stopped.
Temperature and oil pressure seemed fine, no warning lights and noise had stopped so I proceeded home cautiously. Traffic was heavy all the way and I was driving very gently but at times I seemed to have little power. I didn't try to take it above 2500 revs but got the impression it wasn't going to do it anyway. The tip box seemed to be changing up quite early but not giving much power.
Engine still sounding fine, no more weird noises, still no warning lights, temp and pressure all fine.
A few miles from home the ABS and PSM warning lights came on along with the proceed to workshop message.
Nursed the car home, apart from the two warning lights no other symptoms.
Switched off the engine then checked oil (electronically) and it was down to 2 lights/bars!
I looked under the car and there is a flood / river of oil pouring out.
What is the diagnosis from the wisdom on the forum?
