Grill/Mesh
Chigster
14 Jan 2016
174
Hi All,
Thinking of getting the Zunsport grilles for my 996 Targa - I think they look quite good and will hopefully keep out some of the muck!
Question - Car is Atlas Grey. Should I go for silver or black grilles?
Ta!
Personal choice as always but I went black.
PS. Know you have a 996 and mine's a 997 but the colour combo should give a decent idea.
Great look FRZ911, just a couple of questions, if you would please. Did you fit them yourself and did you have to remove the front bumper assembly to fit them from the inside?
I'm looking the the same grills in black for my ocean blue 996.
Hi Steve,
Yep, fitted them myself and didn't have to remove the bumper. Instructions are pretty clear from Zunsport - just take your time and check then re-check your measurements for the holes. Not difficult though......
Arctic silver car and I opted for black grill
Black is a bit more background. Personally I don't like a grill to stand out, find it a bit Halfords...
I have black on my black 996 and they fit well.
The only change I had to make was repositioning the temp sensor as I did not want to cut a hole in the grille for it to protrude through. This involved removing the small clip that positions the sensor on the bumper and relocating the sensor in the plastic housing further back. This is just a case of feeding the excess cable back through the grommet in the housing. I found it easy as I had removed the bumper to clean the radiators before grille install.
Jim.
Has anyone cut their own mesh grill? I did this on my last car and it looked great, but haven't seen it done on here yet
wasz said:
Yep, fairly common and easy to do. cheap mesh off ebay and the rads are protected.
Will look into this, £200 for the set off zunsport is a little steep for some mesh! Although the ease of fitting sounds worth it
124,625
1,442,225
49,063
cchrysos
