I'm getting a front end respray and whilst 'they're in there' I thought it prudent to replace old/rusted parts for new shiny ones.
There are a bunch of rusted screws and other stuff I need to refresh but also I noticed my oil cooler fan cowling might need replacement (See below)
Note the bottom corner is cracked where the screw goes through and also the padding/foam stuff is sticking out...
Is this something I should replace? I can't seem to find the part number for the padding/foam
http://dcauto.gotdns.com/illustration/index/455128333
The keen eyes amongst you will also notice one of the micro nuts missing (Hint, the top one)
Also any other parts people recommend refreshing?
I've got a bit of a list. I've priced parts from Total911 (Not tried the OPC yet) and a place I found in the US as I'm heading over there a couple of times before I get it done. Funny how some things are cheaper here and some things cheaper in the US.
Here is list of what I'm considering replacing in case this is a future help for someone else..
Is there anything else I should think about replacing, 'whilst I'm in there'?
Misc Parts
993 993.628.077.01 01C/.00 01C ($41.26): Windscreen Washer Nozel Left & Right £28.80 each (£57.60) http://goo.gl/Kw1SLK
993.505.521.01/2.01 ($100): 993 Front Bumper Undertray Left & Right £79.20 each (£158.40) http://goo.gl/qyzYDq
993 Standard Body Stone Guard Left & Right OEM £33.60 (£67.20) http://goo.gl/Ebk4DR
993.505.551.00 ($35) : 993 Front Bumper Grill £26.40 http://goo.gl/UOWxHC
Bonnet Badge
993.559.211.00 ($75.96) or 996.559.21.101 (£82.50): Hood crest Porsche Badge
901.559.215.20 ($8.96) : Hood crest gasket £4.40
999.591.423.03 ($2.96) : Speed nut for hood £0.90
Front Bumper Under-tray Supports (Left & Right)
993.505.793.00/4.00 ($20) Support/R
999.591.699.02 Speed nut 4.8mm, superseded to 99959169901 ($1.96)
Oil Cooler
993.624.041.00: ($31.60) Air-guide cowl
900.187.132.02: Screw b 3.5x13 (Nuts)
Padding/Foam stuff??? 964.207.223.01 ($30.00): Air baffle??
Seals (Wing & Bonnet) - Still have to work out the part number
993.505.543.00/4.00 ($48.96): 993 Wing to Front Bumper Seal Left/Right £26.40 each (£52/80) http://goo.gl/L7iaV0
Screws
900.187.103.02 Screw b4.8x16
Misc Parts
Bonnet Badge
Oil Cooler
Screws
