The Baron3
- Joined
- 1 Nov 2021
- Messages
- 178
As per title, the car 1999 C4 Egas throttle.
when hot has an erratic idle and very occasionally cuts out, things I've tried:
Cleaned the MAF and the throttle body, not much change
I've unplugged the MAF no change
I've tried resetting the system by switching the ignition but not so the engine runs and letting it reset following a procedure! No change.
Oil air separator, tried removing oil cap whe hot and it screws off ok, with a release of a little pressure.
The only thing I can think of is air leak somewhere or the idle valve, and I think that is a ***** to get too.
Any suggestions? Thanks in advance
