robbiej said:not always later is better, the 18 model has less features the 17!
best to make sure its capacitive touch which I think these are
Nastymatt said:rob_p said:The 9190 has built in satnav which makes it quite expensive.
The newer version of the 7017 is the 8019 and can currently be purchased for £400. This newer model has the wireless connectivity for CarPlay and theoretically for android auto - but that functionality seems to be a little less robust (doesn't work with all phones etc).
I have the 7017 but may be about to upgrade to the 8019.
I have been waiting a couple of years for a head unit with native WiFi for CarPlay so the 9190DABS will be the unit for me - I really like the integration with the dashcam DRV-N520 so I will get that too.
Would like a reversing camera (might as well do it all while there) but I am still trying to work out a way of doing that with out having to cut a hole in the rear PU.
rob_p said:Nastymatt said:rob_p said:The 9190 has built in satnav which makes it quite expensive.
If you are referring to wireless CarPlay (via wifi) then the 8019 has this - it just doesn't have built in satnav. In my mind built in satnav is not very useful because google maps is always more up to date. Yes you have to use data on your phone but most people have a huge data allowance anyway.
You can also connect the kenwood dashcam to all of these units I think.
Your call obviously...
gerryp said:C11BRA said:I'm looking to upgrade the factory screen to a more current double Din
My old PCM screen didn't have Nav but did have the factory multifunction wheel.
A few questions.
I'm guessing I will lose the multi function volume & tune use. (Not a super big deal as I'm looking to swap my wheel to the basic wheel found on GT3's)
I'm guessing that I'll lose the radio data in the instrument cluster but will the range & mpg still work via the stalk?
Can anyone suggest a good double Din with Apple Play or at least Nav?
I've seen a few surrounds that match the grey 997.1 interior. Are there any to avoid? Or should I just get one off EBay? They seem to come with wiring adapters. Will this just plug & play with my Bose system?
Thanks in advance.
Current set up.
By the way where did you get the steering wheel,gaiter and handbrake done.
Looks great.
Looking for something similar as my interior is grey as well.
Poker2009 said:Thanks for reply.
I've just been told by the installer, they would fit it in the rear quarter glass. Probably I could live with that, as I won't see it.
Fulla said:I'd be interested to know who you are using and costs. I see you are based in London as am I.
Interested in the Kenwood unit myself. My only concern are the functions I would loose through the PCM menu.
