When going over rough road I could hear a slight rattle from inside the drivers door. After removing the door card there was a bit play in the window regulator mechanism causing a metallic tapping when it was moved by hand. The play was removed by adjusting the regulator fixing allen bolt (there are 6) closest to the door lock. No more rattle.
