So I've had an intermittent problem for a few years. When I go to open the driver's door the trigger pulls and the actuator pin stays in the depressed position, the trigger goes all floppy.
I thought as it has warmed up I would take a look at it.
Whipped off the door card, then spent what felt like a lifetime unscrewing the 2 bolts holding the door handle on (the rear one is the hard to get to one, you never knew your hands were that big!).
Luckily my wife was out, so her ultrasonic jewelry cleaner came out and hey presto, 25 years of muck was removed (I took the lock out first).
My question to you guys is what, if any, lubrication do you recommend for the actuator pin? it now springs back beautifully, but once I put it back together I don't want to have the same problem reoccur.
I have a day or two before the new handle gaskets arrive, any advice?
