I would like to code out the auto locking function of my 996.2 so the doors do not lock above the 6mph limit, the double pull of the handle is infuriating. I cant find the correct place in PIWIS to do this.
I also have an issue with one of my keys where whatever I try I can not get it to forget the old seat memory position using the buttons by the sill it has been programmed for. I seem to remember reading somewhere that if you get in this situation then you need to reset the function via PIWIS but again I cant find out where. My other key programming works fine, but the above makes the spare key pretty useless as the seat moves every time you unlock the car with it.
I have had a bit of success with coding, in the fact that I have managed to tell my car it does not have a CD Changer and stop the annoying pop up on PCM2 every time I started the car. Interestingly it has never had a CDC so I guess the coding just got messed up at some point, I removed it from the MOST list and its now great, just turns on as expected. Now if only I could fix the time on the PCM2 to stop showing year 2000 - I guess this is due to the GPS rollover event that happened a couple of years ago and is not fixable.
Going to be retrofitting cruise too once I can stomach the ridiculous cost of the stalk.
