Errr.... How do you work that out? Why 0.4 bar assistance to produce 5% more power? I reckon 0.05 bar is about 5% increase in pressure
So, 0.05 x 3.6/2 x 7k = 630 l/min
Easily achievable with a 12 v electric motor running at 25,000 rpm (as they claim). However, I would be a little concerned about the life expectancy of the alternator if it's drawing that current all the time!
Actually, I wouldn't mind betting you'd get the 15 bhp just from that width of intake tract and open paper filter alone... What does a K&N induction kit give you?
The case I was refering to is my original premise of matching Turbo 1.4 bar total (0.4 bar additional)
I get 0.4 bar ASSISTANCE to produce 30% more power (to match Turbo)
So ADDITIONAL 5k LPM as stated.
Now I said that this is more than 3x a 240V / 1,400W (1.9PS) Dyson ASSUMING it actually is as efficient.
So if we assume the eCharger is a powerful same as a SINGLE Dyson (which it can't be, as it can't draw enough current at 12v) the it MAY give 10% gain (1/3rd of 30%)
You are, however, correct that a K&N and CAI would blow this garbage into the weeds.
You don't need an intercooler unless you are substantially pressurising the air: I don't think 0.05 bar will produce a measurable temperature rise tbh
I do need an intercooler as I am adding 0.13 bar minimum (I would point out that my dig was mainly at the warm air intake, the lack of IC simply underlined the "heath robinson" air)
I don't think VW spent a single penny (or cent) on the Mini BMW did, though...
You misread my "mini TURBO-SUPERcharger system" (note: a "mini" means small when not a proper noun and with "TM" next to it followed by "Adventure") - I ferer to the SMALL/TINY etc TSI system fitted to VWs 1.2 and 1.4 petrol engines.
As a final go at trying to prove this MAY work for your benefit, I will work from simplified energy principles (rather than volumetric analysis):
So, if we assume 25A is safe continuous current draw (!) in the car, this results in a 300W fan power. A 300W fan power will allow a FI of 0.028 bar (which I will also defer to you and assume it is quasi-static and requires no IC, but please, for goodness sake - SUCK IT IN FROM OUTSIDE THE ENGINE BAY!!)
Note: 25A at 60% alternator efficiency will require an additional continuous load of 0.79 PS from the 14V alternator.
The 100% efficient conversion of 0.028 additional bar FI to a 996 3.6 NA engine rated @ 320 PS gives an additonal 2.1% gross gain = 6.72 PS
Now deduct the 0.79 PS production load, gives a maximum possible 5.93 PS gain
This does assume all the gubbins works (does not detract from Porsche's fine engineering), no heat is generated and the unit does not add any additional friction or turbulence to the air flow, it can thoughput 102.8% * 11,250 LPM and the actual fan assembly is 100% energy efficient.
As you say, get a K&N fiter!
