Looking for some advise generally
I want to hard wire my new Dashcam ( Nextbase 300 12/24v ) ..directly into the fuse panel.. this seems to be the general path most people are going down ? I looked at the forum and there was a bit of confusion ( me most likely !) as to which fuse spur i should piggy bank onto .. I naturally thought the cigarette lighter one but anyone else have advise on this .. oh what fuse number !!?- Gen 2 997 C4S?
Also any advise on keeping the cable hidden and neat ?.. presume i should try to tuck it under the trim above the rear view mirror and somehow feedback back to the fuse box..not sure if the lid of the fuse panel will close with cable going into it .- i was going to use a compatible hard wire kit, but it does have a little square box .. not sure where to aim that ... will i need to earth this and if so where .. fuse box? i maybe making this sound complicated !!so
is this a pretty strait forward job?
Finally am i correct in saying battery will not drain as this will be active and come on "only" when the ignition switch is turned on - a tad worried about that.
Thanks in advance to any feedback -much appreciated
