Creaky arm rest / storage lid
markz86
19 Nov 2013
194
My centra arm rest creaks when I rest my arm on it or put pressure on it in any way.
It is the 2 rubber feet against the plastic base that is causing the noise. Does anyone else get this? Is there a way to eliminate the noise?
I can't believe it came out of the factory with this noise?
It's a small in the grand scheme of things but I'm on a mission to elongate all unwanted noises at the moment.
Mark
Not sure if that is your noise but to check then a thin smear of vasalene on the rubber grommets and see if it still does it ..
If that does stop it then wipe it off and use a rubber replinisher or Crytox from an OPC to lubricate and stop the noise.
You could also use teflon tape where the grommet rests when closed .
I suspect it will be the lid arm though .
Silicone spray works well.
Have zero vertical play between the 2 rubber feet and the hard plastic, so no creak on my car.
However, have had plastic/rubber creaks on other cars and have always found a squirt of Gummi Pflege to do the trick.
Dermot was right, it was the lid - Northway have sorted it whilst they had it in for a few other bits.
Thanks for pointing me in the right direction!
1,442,226
49,067
e46m3
