Hi Guys,
Got a new problem on the GTS, recently replaced my air compressor due to the power wires snapping clean off.
Bought and fitted an eBay unit, seems to do the job just fine however, I did find that it was running a bit more often than it should, every few mins, it comes out to top up the air, so clearly a leak.
I did get an occasional error with "chassis system error", when this happens, it doesn't allow the car to go to the very higher or lowest level and sometimes, no sport mode.
Checking codes, 1772, signal lead for pressure sensor.
Did some investigative work and found some air leaking from the brown air hose which is the tyre compressor supply, where it meets the swivel output joint.
Fresh cut hose and some sealent for security, no more leaks.
Thought this may stop the compressor coming on, it seems it needs to come on everytime I raise the car, as if it does not use the air tank supply and I still get the above 1772 error. I'm not sure if this is triggering due to pressure falling below a threshold.
Right now, I'm stuck, the air suspension operates fine, remains level and at the height it is left at, even after 5 days of no action, I've used soapy water to spray around the air compressor and distribution block during inflation and after compressor switches off and there are no leaks. The only thing I have not check is if it is leaking through the exhaust, if that is possible but otherwise, I have no clue as I have not disturbed any other areas.
I have a basic diag tool and I can see the system pressure drop off within just a few minutes. When the error occurs, it doesn't allow the accumulator valve to work and I guess this is where it stores the air to allow a fast increase in suspension height without using the compressor.
Do I have a leak, does it need calibrating, is my ebay compressor crap, what have I missed?!
So, I'm stuck, if anyone has any clues as to what I can do next, that would be great!
Other issue is coding my ballast, PIWIS is the only way of doing this right?
Cheers!
Cheers!
