Gwsinc
- Joined
- 4 Sep 2019
- Messages
- 525
Hello all. I noticed a while back that one of the middle oil level sender studs had broken off the tank, it leaked a little, nothing to write home about, but enough to put it on my list of things to do. So today I tried to install a new gasket to slow the leak (the old one was 25 yrs old and very flat!) but one of the old gasket's aluminium rings had fused itself to the broken stud! I couldn't get it off annoyingly.
I did the best I could with the new gasket by cutting the equivalent aluminium rings out and putting a little gasket sealer along the side of the seal.
I suspect this will be ok for a while but I expect a replacement oil tank is the next step, which I'm happy to DIY. I plan to get a used one and replace all the seals and o rings while I'm in there.
Has anyone got any tips on where to get a decent used tank, there are a few on eBay for reasonable money? Any other hints or tips?
Thanks in advance
Thanks in advance
