Master_Betty
- Joined
- 26 Apr 2015
- Messages
- 148
orangecurry said:Michelin Tyres said:Master_Betty said:Michelin Tyres said:It's simply not worth often risking the 4wd system as often the sizing can be slightly different and you never find out until the drivetrain starts making grumbly noises :sad:
You're not suggesting that fitting non-n-rated tyres risks damage to the 4wd system are you?? There is obviously tolerance but you get variation in rolling circumference between front and rear, between different manufacturers of tyres, not to mention a fair difference just from losing 6mm of rubber during the life of the tyre. Those are all realities for all tyres, not just if whether they are N rated rubber compound or not.
Best to stick to the facts.
By the way.. What wasn't factual???
The non-factual bit? I've put it in bold for you - you've made a statement with nothing to back it up, yet included the word 'often'.
You are absolutely correct in the fact that tyres marked with a certain size on the side are not exactly the same size as each other.
But they will all be within tolerance of the 4WD system, unless of course you know of some that are not?
... or know of some confirmed cases of 4wd transmission damage from fitting non-n-rated tyres?
