Hi All,
Bit an odd first post. Bought a 997.2 4S PDK cabriolet back in January 2022 with a 2 year Auto Guard warranty from the other end of the country.
Had the car checked over by my indie when I got it home and the car was spot on, apart from a weeping coolant pipe which was replaced with no issues under warranty. Used the car as normal for a few weeks then came to use the car and it wouldn't crank over. Spoke to my indie and he said it may have gone to sleep and to lock and unlock it using the key in the door. I did this but I don't know if this worked out of coincidence or through this but it worked as normal. Drove it all weekend, doing a few hundred miles stopping and starting and around town with no issues. Left it for 3 days and it hasn't started since.
Have been unable to get it into the local OPC but my indie has been fitting it in between jobs as he is snowed under and 6 weeks in I still don't have it back. Luckily I have been busy and haven't really needed it! He has checked starter motor, starter relays, ignition switch and wiring. He seems to think it could maybe a VTS issue which is inactive or, a DME which he says may have to go to OPC. There are no faults with the car, it just will not crank and I think he said he can't get power to one of the relays, maybe number 2. I wonder if anybody else has had a similar issues.
Many thanks,
Dean
Many thanks,
Dean
