992 remap adds 200bhp
wasz
Paul Ricard
28 Dec 2012
3,107
Interesting they say the carrera and the carrera s are mechanically the same, just with different maps.
Litchfield adds 200hp to 992 Carrera 911
Stage 1 map takes outputs of turbo flat-six to 580hp with no hardware changes
Litchfield has launched a new Stage 1 map for the 992 Porsche 911 that can extract a further 200hp from its turbocharged flat-six engine. The Litchfield software, which reduces emphasis on emission control to maximise performance, pushes total output to 580hp for both the Carrera and Carrera S models, making the entry-level 992 as powerful as the 991.2's most potent model, the Turbo S.
Naturally that power gain is accompanied by a big growth in torque, with maximum twist now set at 480lb ft – 90lb ft more than standard. That being said, Litchfield's changes do make the 3.0-litre boxer a tad less rev hungry, Porsche's flat power curve swapped for one that begins to taper off towards its top end. The drop in punch is tiny, however, showing that you'll still be rewarded for letting the motor rev out.
Interestingly, Litchfield said that both the Carrera and Carrera S share the same powertrain hardware, with the former model only losing out from the factory due to its digital settings, meaning bringing it into line with the S requires no extra work.
Now that Litchfield has launched the Stage 1 map with a price of £1,194, it anticipates a week's wait for customers wanting to get their new 992 (or a used one) on the Gloucestershire firm's rolling road. The company is also working on a higher-spec upgrade that will include the option of a different exhaust system, supplied either by Remus and Akrapovic to free up airflow, reduce weight and enhance noise. Should you just want the latter for your 992, a less restrictive silencer will also be available for otherwise standard cars.
https://www.pistonheads.com/news/ph-porsche/litchfield-adds-200hp-to-992-carrera-911/40852
That could lead to some interesting warranty discussions.
That is some impressive performance gain for not a whole heap of £££...
so why do I need a Carrera S then, if not for the 6 pot caliper brakes?
Always like a it of extra oompf.
It's a really tempting price point from a well established player, however, I'm sure warranty is a potential issue should anything engine related go bang. I also fear for resale as Porsche will be able to see any flashes of the ECU and I presume would flag the car, causing a hefty drop in value. All this presuming that extra poke hasn't already caused an 'off".
I need to work out the man maths on this one.
Might need a lie down... 🧐
I'm sure this contradicts the early press realise on the 992 S having a different turbo/flange/gizmo (not sure on the exact engine part) to the base Carrera. This was certainly reported on the 991.2 as a differences on the S.
The info was the 992 Carrera had smaller turbines and compressors that feature in the new 992 S turbochargers aside from a few downgraded chassis elements from the spec
200hp from a tune :grin:
Well sorry but this is not correct. It was tuned on a 4s which has according to Porsche 450ps. I have run and tuned one already and on the road it makes 393whp stock which is about 12% transmission loss. If you take the whp in the dyno chart below it shows 454whp (blue) so an approx increase of 60whp. 454whp does not under any circumstances get you to 580ps - it might get you to just over 520ps. So that is around an 80ps increase from the tune.
The s model just like in the 991.2 has larger Turbos. They are not the same as the standard car.
Ken
124,625
1,442,217
49,058
GoochyTM
