pandaboi78
- Joined
- 19 Apr 2023
- Messages
- 4
If you turn them over do they have a cup or socket? If so they may well be the two 'plugs' that locate the intake airbox. Under the engine lid remove the cover and then the two fans you will see the centre air intake box is located along the upper side by plugging into these two. They do have a habit of pulling out when the air intake is lifted away, often when the oil filter is changed.I found these loose behind the rear trim panel under the rear window.
They were in the channel behind the carpet below. Anyone know what they're for?
