Credit where credit is due deMort, plagiarism is not my kinda thing..though cynicism comes entirely naturally to me.. :grin:
The Vehicle Health Check (VHC) retained as a print out would seem to be of value in terms of maintaining a reasonable history file, thus perhaps may be considered as of value to quite a few customers, and in that regard an improvement over just a basic MOT certificate issued...?
My car having had the benefit of being subjected to a BMW main dealer multipoint checklist at the dealership I bought it from less than a year ago, then soon after given a complimentary health check at my OPC, followed on three months after purchase having a service carried out immediately followed by a 111point check all at my OPC, I expected there was little chance of anything being found to create any real issues, and which fortunately turned out to be the case during the MOT and brake fluid change.
Only items suggested to keep an eye on were rear tyres at max 5.9 and min 4.2 across all six points for the two tyres.
Rear brake pads getting low at 6.0mm
Rear number plate lettering beginning to crack... which was fitted new by the BMW supplying dealership when I bought the car just under a year ago..!
Apparently the 997 reinforcing horseshoe plate that I mentioned as a possible mod, was looked at but not available on this model (991) with mention of SY, 195555 ?
We have discussed the exhaust fixings before Iain, and my thinking is that the fixings should be of the same or better quality than the rest of the system, and therefore last at least as long as the system if not longer, as was ever my experience in the air cooled days, and which you seemingly backed up with an image of an air cooled engine disassembly showing no issues with broken fixings..
IF there is some justification for fixings that corrode to the extent that these seem to and subsequently require the amount of extra work, after market jigs and expense as has been recorded by many, I would be more than pleased to be educated as to the reason these particular fixings are selected as matching Porsche engineering ideals..
That it seems the exhaust fixings may be excluded from the extended warranty kinda causes the cynic in me to twitch somewhat..!
As ever thanks so much for your much valued input Iain.
