Finished painting the rear cubby, still need to get the battery tray welded in and the hole in the wheel arch liner patched.
Got the torque tube reinstalled, note the amateur error again here! I installed the torque tube cross support (the aluminium section) but this prevents the install of the torsion bar and handbrake cables later on. So if you are doing this then leave the aluminum cross support until you've installed the torsion bar and handbrake cable! Also a nice new sound absorber for the gear shifter. The torsion bar is resting on the supports, I did it this way so I don't have to remove the torsion bar again to install it at a later time. Will strap it down if I need to have the car transported for the bits of bodywork.
Next up was to assemble the torsion bar, I'd previously taken some pictures and rough measurements with a piece of cardboard so that I could try and get the bars in roughly the same position to keep the correct ride height.
Raised the torsion bar into place using the transmission jack and a pair of axle stands to keep it at the right angle (very important). I messed this up the first time trying to install it when it wasn't completely horizontal and had to re-paint the mounting areas where they got scratched up!
Gave the non-contact surfaces of the hubs and stub axles a coat of Owatrol Oil (had seen this used on a 911 restoration video series). Not sure if it will hold up as it seems to be a varnish type coating.
Then finally making some progress!
Got the assembly bolted back on to the chassis now and the parking brake, hubs and stub axles are fitted. Next for the disc brakes, I'm going to paint the bells on the discs with silver brake caliper paint first. Then I might be ready to put it on wheels and give it a clean before I remove the engine!
Had some fun with the rear wheel bearings, the left side went in super easy. I had placed both bearings in the freezer overnight and heated up the trailing arm with a MAP torch for about 6 minutes, until water boiled on contact with the bearing surface. I picked up the bearing and it slipped straight into the arm by hand! (yes I know the circlip is missing in the photo but was fitted shortly afterwards)
No such luck though with the right side, on the second attempt I managed to get the bearing in about 25% of the way and then resorted to using my bearing tool and a 2 foot breaker bar.
Nice new classic line rear brake shields (considerably cheaper than the Porsche ones), think these were from heritage parts centre (the VW people).
Which brings us right up to date, and last weekend I managed to give my new pair of rear Sebro brake discs a coat of Halfords finest brake caliper silver paint (friction surfaces suitably masked with tape). I then turned my attention to the ABS cables which needed new earth terminals and got cleaned up with brake cleaner.
I've started making some new brake lines for the rear, and need to setup the parking brake and attach the discs, and calipers.
Soon be on its wheels hopefully for a clean and then starting the process of removing the engine for the rebuild!
