I can see that the 3.4 OE coil packs have a shorter case (and shorter bolts).
The 3.6 OE coil packs look to be bigger (probably improved moisture resistance) with longer bolts. I think this can be used on the 3.4 engine as long as longer bolts are employed.
Q1: Do the larger case coils require the heat shield to be modified with a 3.4?
Q2: Do the larger case coils work with the 3.4 plugs or do they need to be switched for 3.6 variants?
Answers to this would be a helpful addition to the FAQs...
