P0016 fault code basically means the position of the inlet camshaft is incorrect to the seen position of the crankshaft .. outside of limits for whatever reason and the car flags a code to tell you this .
Reasons .. well the logical ones ..
Cam sensor faulty ..
Wiring for Cam sensor faulty
Cam chain stretched ..
Cam in an incorrect position possibly due to the vario cam incorrectly adjusting ...
This is the problem one as i would assume the car would flag a fault code if it thinks this is at fault .. not going to discount it though as what you have described with the cold making a difference then this is certainly possible .
I still think it would flag a fault code for this which it hasn't but worth checking .
NA cars and i see a code listed .. P0017 which is exhaust cam out of position .. we don't have that in our market .. if there is a sensor such as this then that would rule out Cam deviations as you should have both fault codes .
I would still like the deviations checked though as the above bit is only something i have read and know nothing about .
Good shout to say you are NA though ... i don't think we get many of you guys here .. i believe it's renlist you tend to use ?
Kinda honoured if you have come here after perhaps asking there .
I've never had the pleasure of changing the solenoid on one of these but i would certainly expect the cam cover will need removing ... i see no way of replacing it otherwise
Check if its covered under warranty . if so then let them have the headache of diagnosing it
