Hi all
I've got the PSE system on my C4S. I removed the box because it had a rattle, which turned out to be a broken actuator arm causing the flap inside the pipe the rattle.
The silencer to cat pipe was also fractured.
I've sourced a non 'PSE' standard silencer from another C4S to use as a donor box as I need the pipe to the cat and the brackets.
The new silencer is in far better condition overall. The question is, can the pipework including valved section from the PSE box be transferred on to the standard silencer, after opening the top port??
