996 cylinder head bolt tightening sequence?
Harv
18 Sep 2014
1,204
Does anyone have a photo or PDF copy of the cylinder head tightening sequence they could post here for the 996 3.6 engines?
I think the torque spec is initially bolt up to 15ft lbs and then once round at 60deg turn and then repeat again??
TIA
It's a bit more tightening than you were expecting.
Head Bolts.
Tightening specification for cylinder-head screws:
. Initial tightening in accordance with tightening sequence 30 Nm
(22 ftlb.), undo all screws again
. Initial tightening in accordance with tightening sequence 20 Nm
(15 ftlb.)
. Final tightening in accordance with tightening sequence 2 x 70°
torque angle
Then the 4 allen head bolts.
Position and tighten 4 pan-head screws with M6 x 30 captive ~
washers (hexagon socket 10.9, ajf 5) -Items 1 - 4- on the
chain space. Use of a magnetic bit is recommended so that the
screw to be fitted in the slot -Item4- cannot fall into the crankcase
124,589
1,441,843
49,020
cooper9000
