As described by Scottie
I took the car into OPC Guildford as is was due a major and asked them to investigate the metallic click.
They say it is internal to the rear diff.
A replacement is £4k so I'm hoping someone may know of a less expensive fix?
Any good gearbox guys in the south?
TIA
Only mine is a Turbo but I guess the 4WD Tip setup is the same.scottie530 said:When moving off from stand still I get a loud metallic pinking noise from under the car, which sounds like metal stressing (can't think of any other way to describe it) once on the move I don't hear it again until I slow down under breaking. I then get it again when I accelerate. The car drives fine and I thought it would be an exhaust mount or similar.
TIA
