HI guys, I am posting from Canada, just trying to see if anybody has had the same issue like i have with their 996. I have a 2004 40th AE, and have had issues with it starting pretty rough lately.
Dealer I bought it from looked at it but couldn't find what is wrong with it. They want to wait for the engine light to come on before diagnosing :dont know: I got a little video that shows what's going on. This is as bad is at get's usually it doesn't hunt that long, but it is what happens every time the car sits for a day or two.
http://www.youtube.com/watch?v=Go6KYA4_otQ
Ones it settles at about 1100RPM it will sit there for a minute or two until it warms up, drop down to 750RPM and run like a charm after that. Pulls strong, and starts without any issues while at temperature. If you experienced this before or have seen it somewhere i could use some ideas as to what it might be. Dealer apparently checked for vacuum leaks and compression, it was all good. I did have a topic open a while back on Rennlist about it but without the actual video.
http://rennlist.com/forums/996-forum/761203-rough-idle-help-my-local-dealer.html
I also did a bit of data logging with Durametric software at startup, but it all at least, seems fine.
