Hello everyone
I developed a rough idle on my 996, feels like it's running on one or two cylinders down.
So far I've done the following, partly in seeking the fault and partly as general maintenance
- Compression test (all good)
- Oil and filter change (no metal particles in old filter)
- New set of plugs
- New set of coilpacks
- New lambda sensor (this came up on the fault code reader)
- Brief check for air leaks
- Inspection of earth straps
The rough idle remains.
I'm thinking of cleaning the MAF next. Any other ideas, or common faults I'm unaware of?
Thanks in advance
- New set of plugs
Thanks in advance
