Oh I see...bigchunk999 said:The relay still stops them opening even if you have the switch, its a noise polution thing (keep the exhaust quiet in built up areas).
Now that sounds like a plan... She is going in for some suspension work tomorrow so will ask them to have a look at the same time then.cheshire911 said:My money would be on a loose heatshield. The bolts corrode and fall off so makiing it rattle and/or the heatshield itself becomes corroded and breaks away from the mounting bolts.
The sort of job for an indy I'd recommend. OPC can also do it, but may be more expensive. You can ask an OPC to take a look and quote a fixed fee and then ask an indy and compare the two figures.
Maybe a little 8)cheshire911 said:That was fortuitous! You may make some savings on labour combining this fix with other suspension work.
