On my way to work this morning all was well, listening to the radio and coasting to a set of lights and suddenly, without warning, the engine stops. No warning lights, no stuttering just off.
The engine turned over but wouldnt start so I had it towed back to my local indy who initially thought it was the fuel pump or relay.
Hes plugged his PIWIS and durametrics in and the fuel pump and relays are fine. The only fault code in the DME is P1671 'purge fan' or 'short circuit to ground/B+'
Anyone got any idea what this means? My indy thinks the ECU is likely to be f*&cked.
Any advice?
How much is a new ECU? Can I get one from a breakers? Could it be anything else?
:sad: :sad:
Any advice?
:sad: :sad:
