Spookymooo said:
2005 997 C2 3.8S
Following the appearance of "battery charging" warning I have started to remove the alternator to ascertain which regulator to order (following advice from helpful forum member)
I have also seen threads concerning the failure of a starter motor to alternator cable which has been cited as a common problem on early 997s. (Caused by overheating, leading to conductivity breakdown)
How could I confirm the cause of this problem before I start buying bits and pieces?
Cheers Rob
Hi there
Have you sorted this yet ? This exact thing happened to my 2005 997 C2s.
The other symptoms my car had were:
1. Slow to non existent cranking on hot start (OK ish when cold).
2. Battery needing constant top up charging.
When I tested the voltage at the battery = voltage at rest 12.5v, voltage when idling 11.8v, voltage @ 2000rpm 12.8v.
But the important aspect for my particular issue, was the voltage at the alternator at idle was 13.5v !
This meant that I was having a voltage drop from the alternator to the battery of around 1 volt.
This was the conclusive proof for me that the alternator cable was at fault. I googled 997 alternator cable and found a brilliant article with write up and picture sequence on how to replace it.
I went to my local dealer and they had one in stock (upgraded part number, so a known fault) it cost £80. I fitted it and it has totally transformed my car. I get 13.8v at the battery so it charges itself completely now, regardless of what type of journeys. But the biggest improvement is in the starting of it, it used to crank over really slowly (ridiculously slowly starting it when hot) to the point that I never really had confidence that it would definitely start ! But now it cranks over like it is on steroids !! cold, hot, or just after turning it off, at all times it is perfect.
I think that this problem affects a lot of 2005 2006 997s and it is only when it gets really bad and stops charging the battery that people have to sort it.
I hope you have already sorted out your car but if not I hope this is of some help to you or anyone else having this issue.
It has completely transformed my ownership from having worries about flat batteries and worrying if my car would start, to now having total confidence in any journey of any distance.
Andy.
