Moderator
- Joined
- 8 Feb 2008
- Messages
- 7,361
For more info on the Voltphreaks Lightweight 12V Lithium Car Battery, can be found at http://911uk.com/viewtopic.php?t=56030
GROUP BUY
At least 5 orders are required to secure the Group Buy 20% off rate
911uk has been able to secure 20% off the current price of the Lightweight Voltphreaks 12V Lithium Car Battery
Recommended model for Porsche Cars is the
VPH-750
VPH-900
VPR-P6
Also for the VPH900 and VPR-P6 only, you will get free SAE posts, M6 to SAE battery terminal adapter kit (aluminum)
The recommendation for Porsche cars is the VPH750 at a minimum, while for users that want more capacity or power, the VPH900 or VPR-P6.
DATA SHEET FOR VPH 750 AND 900 SERIES BATTERIES
DATA SHEET FOR VPR P6 SERIES BATTERIES
The best is the VPR-P6, it has the best weight/performance ratio, plus it is compatible with any standard mount for the Odyssey PC680.
If you want the lightest possible weight, get the VPH750. If you'll be starting the car when it's extremely cold often, get the VPH900. If you want the car to last a few weeks parked, get the higher capacity VPH900. If the main purpose of the car is as a track car, get the VPH750. Here is a comparison chart for Voltphreaks Lightweight 12V Lithium Car Battery
This is the current state of the art in lithium battery technology. It is 3 to 5 times lighter than a comparable lead-acid battery of similar specs, and lasts 5 to 10+ years with proper use. Up to 5 times the life of a lead-acid battery; racing teams are replacing their Voltphreaks battery every 3-5 years instead of every year with their lead-acid battery.
Retail Price list for Voltphreaks Lightweight 12V Lithium Car Battery
Group Buy 20% Discount (exc Shipping, UK Taxes)
@ £/$ Exchange Rate as at 23/3 of £/$1.65
VPH-750 $899 = $719 Group Buy rate = Base GBP Price £435*
VPH-900 $1,199 = $959 Group Buy rate = Base GBP Price £58*
VPR-P6 $1,280 = $1,024 Group Buy rate = Base GBP Price £620*
996 / 997 GT3, Minimum Recommendation is VPH-900
Shipping will be to a single UK location from the USA, then Good will be forwarded on using Tracked UK Service.
* Shipping Costs are as of yet, TBC. This excluded any final UK Duty Charges, at this time budget an extra 20%.
Voltphreaks can also be contacted by PM to user "vph_tony" or by email to [email protected]
Interested Parties
1. Stuart - 996 GT3 - VPH-900
2. Ian - 997 GT3 RSR - VPH-P6
3. 911uk - 964 RSR VPH-900
4.
5.
Porsche User Feedback
GROUP BUY
VPH-750
VPH-900
VPR-P6
Interested Parties
4.
5.
manogh said:Car - 996 GT3 RS 2004
Just buy a Lithium Ion battery from Voltphreaks....modern technolgy.
You can remotely switch it off yourself or it will do so automatically and you never need to worry about recharging and removals....plus it weighs 2kgs compared to 17.
You obviously dont drive your car in the winter so the cold start problem is a non-issue.
I have mine for a year or so.....bloodly brilliant. I so love the wizardry and benefits of modern techno
Note, * POSSIBLE INCOMPATIBILITY
Lithium batteries could be incompatible with some (not all) Porsche GT cars. We have heard from some customers that their GT's alternator may not maintain the right voltage to charge a lithium battery. We are not aware of any other cars that show this behavior.
Almost all car alternators (inc Porsche GT) maintain 14V to 14.6V to properly charge the car's battery, and this is what the Voltphreaks battery expects. Some Porsche GT's undercharge their lead-acid batteries, this is not compatible with the more efficient lithium batteries. Below 13V, a lead-acid battery will be partially charged, but a lithium battery will be barely charged.
If purchasing a Voltphreaks battery for a Porsche GT2 or GT3 (or if you suspect your car's voltage may be incompatible), measure the voltage with engine on (so alternator is supplying power) first to insure compatibility. Voltage at idle should be around 14-14.6V. This likely only applies to Porsche GT's, as we have not encountered this issue with other cars including other Porsches.
