997 : 2004- 67
996 : 1997-2005 34
Macan : 2014- 6
Post new topic   This topic is locked: you cannot edit posts or make replies.
carruthers
PostPosted: Sun Jan 19, 2014 2:48 pm    Post subject: Reply with quote
Well that is up to the individual, doesn't get away from the fact that Porsche will permit work done by a VAT registered concern and that if the work is satisfactory with genuine parts used then there is no problem, in any case you will only have a problem if you are claiming for a fault or problem associated with the work done. I don't see a problem with an Indy changing your brake fluid for example as this will not affect any claim unless you have an associated brake problem.
PostPosted: Sun Jan 19, 2014 2:56 pm    Post subject: Reply with quote
Absolutely BUT the people deciding whether it was 'associated with the work done' would be Porsche.
If they decided that a major engine problem was associated with the fact that a car had last been serviced by a non-OPC garage they'd refuse a claim.
I wouldn't want to be that individual.
PostPosted: Sun Jan 19, 2014 2:58 pm    Post subject: Reply with quote
jamesr36 wrote:
Thanks for everyone's advice.
I reckon brake pads and MOTs at the local garage/indy with OEM parts. Everything else at the OPC
As the originator of this thread has made his decision I have locked it.
Post new topic   This topic is locked: you cannot edit posts or make replies.   All times are GMT - 12 Hours
Goto page Previous  1, 2
Page 2 of 2
