Posted: Sun Aug 04, 2013 9:53 am Post subject: Super Unleaded....!???
Quick one?
Do all members run their 997s on Super Unleaded, ie Shell Nitro, BP ultimate etc...?
I read somewhere that the timing self adjusts if the lower octane fuel was used...????
Fatbloater Silverstone
Posted: Sun Aug 04, 2013 10:17 am Post subject:
Its a thoroughbred animal, it needs feeding top notch food else it'll run like a donkey _________________ "Wax On, Wax Off"
Collinite Appreciation Society
nhenson Trainee
Posted: Sun Aug 04, 2013 10:34 am Post subject:
I agree, and only ask as last night I found myself driving past three supermarket filling stations to get to a Shell garage. It was touch and go as the range calculator and Sat Nav kept disagreeing as to wether we had enough fuel to get there...!!!
We did, but was just wondering if I was panda-ing to my ODC ways once more...!
JohnnyDangerous Estoril
Joined: 12 Jun 2013 Posts: 3613 Location: East Sussex
Posted: Sun Aug 04, 2013 10:41 am Post subject:
I run mine on Tescos Momentum, 99 octane and pretty cheap, as an emergency measure I carry a tin of octane booster in case I can only get 'the cheap stuff'
Heres a link to some very reasonably priced and a good octane booster
They claim more MPG, I have noticed whenever I use 118 octane it seems to last a lot longer than is expected (considering the car is on 100% throttle when im using it) I might try a fill up with 'normal' unleaded and a half bottle then full bottle of this and see what difference if any it makes, anothe rgood product is Power Pour, your motor simply WILL NOT detonate with this stuff, £15 a bottle or £10 if you buy a case. _________________ I came into this world screaming and covered in somebody elses blood! I have no problem leaving the same way!!!
cheshire911 Estoril
Posted: Sun Aug 04, 2013 10:44 am Post subject:
The engine management system adjusts for the lower ocatne rating of 95RON so in that situation where you were low, running on 95RON would have done no harm to the engine. The handbook for my 996 Turbo does say to use Super Unleaded 98RON. I'd be surprised if it is different for a 997.
You may need to see a doctor if the OCD and Porsche Paranoia symptoms become worse. _________________ 996 2002 X50 Turbo Manual
Posted: Sun Aug 04, 2013 10:53 am Post subject:
I'll just elaborate on my answer...
I always use high octane fuel, however there have been occasions when Ive been stuck and had to use the cheap stuff. I put as little as possible in to get me home and to my regular garage, then fill up with normal stuff.
I like the idea of carrying octane booster so I'll probably do that now.
Also I'm getting 32MPG on my twice weekly commute (180 miles all clear motorway) which is in general above what most people on here achieve, I've not tried normal fuel but I think high octane usage has something to do with that figure.
And yes, I do drive like Miss Daisy's chauffeur ! _________________ "Wax On, Wax Off"
Slayer Indianapolis
Joined: 29 Dec 2010 Posts: 2457 Location: United Kingdom
Posted: Sun Aug 04, 2013 10:55 am Post subject:
I doubt the Porsche centre's use high octane stuff for the cars _________________ Current: 981 Cayman S with some goodies
Sold:
Golf R 7.5 FL ( Atlantic blue with Akropovic exhausts/ Performance pack)
Golf R FL 7.5, A45 AMG FL, Golf R , Golf GT, VW Golf R (Reflex silver) 2016
VW Golf R, Golf Match, VW Scirocco 2TDI R line-BMT , 997 Gen 1 Turbo , 997 C2S(Aerokit), 997 C2S, Cayman S, 997 C4S, 997 Carrera, Boxster
Posted: Sun Aug 04, 2013 10:58 am Post subject:
The guy I got the car from said it was very sensitive to cheap fuel and that it took a while to grt back to full performance after filling up with super again, as soon as I fit the standalone ecu I can switch maps for whatever octane fuel im using. _________________ I came into this world screaming and covered in somebody elses blood! I have no problem leaving the same way!!!
GT4 Nordschleife
Joined: 08 Nov 2008 Posts: 30174 Location: Hertfordshire and Hampshire
Posted: Sun Aug 04, 2013 11:33 am Post subject:
You CAN run on 95, but don't.
As we are talking 997, the 997.2 DFI really hates 95 (the 997.1 less so)
But the manual and fuel flap say 98 RON, and for good reason.
Not only do you lose power, but that cheaper fuel is used quicker.
The engine will run hotter too on 95 RON, and that is not good for all sorts of longevity, thermal stress and reliability reasons.
Expect to lose about 30BHP and a load of torque if you use 95 RON fuel on a Turbo (less so on an NA, but still more than 10 BHP).
95 RON will also result in increased consumption at a steady speed - by up to 2-3mpg (so an easy 10%).
So a real false economy to fill with the cheap stuff.
The DME can "learn" the fuel grade (and atmospheric fuelling effects), so if you are planning on using a higher grade than in the last tankful, do a reset for immediate effect (rather than waiting for up to half a tank to passive reset).
DME reset is via key, Throttle Body reset is via key
Reset via key requires turning the key to ignition "1" (the position when all the lights are on on the dash) and leaving it for 60+ secs (DO NOT TOUCH THE THROTTLE PEDAL), then switch off for 10+ secs and you should be able to hear a few clicks and whirs from the engine bay as it recalibrates the adaption values.
Adaption must be performed when ambient temps are > 10°C
cheshire911 Estoril
Posted: Sun Aug 04, 2013 11:52 am Post subject:
GT4 - thanks for a comprehensive response. I have a 996 Turbo with X50 and use Super Unleaded. Question is, is Super Unleaded the same octane rating and basic detergents that are required whether it is from Sainsbury Supermarket or from BP Ultimate, Shell V-Power Nitro etc?
I appreciate the brands such as Shell market themselves on extra detergents and additive that clean the engine and injectors as we drive, but is the Sainsbury Supermarket stuff really that bad as to avoid - given that it is 98 RON? Bit like generic medicines - generic atorvastatin is as good as Pfizers Lipitor global brand because there is a Standard of manufacture to bemet and manufacturing sites are inspected to ensure the generic meets the standard of the brand. The difference is thaat the generic is £3/month versus Pfizers global brand at £30/month. Hence the NHS drives the usage of generics.
Does the car industry accept 98 RON from Supermarket does not harm the engine and is the same as Shell V-Power? If so then Shell V-Power is charging a premium for some detergents in theirs that are not in the Supermarket product? And anyway, Supermarkets buy their fuel from the big refineries of Shell and BP anyway?
Value your thoughts and advice on this topic please. _________________ 996 2002 X50 Turbo Manual
Posted: Sun Aug 04, 2013 11:59 am Post subject:
I can tell you that Sunoco race fuels are no longer used in a couple of the bike classes as they were found to be nothing more than supermarket fuels with a few additives thrown in _________________ I came into this world screaming and covered in somebody elses blood! I have no problem leaving the same way!!!
GT4 Nordschleife
Posted: Sun Aug 04, 2013 12:07 pm Post subject:
The RON weight is what you are buying.
Any discussions into snazzy detergents or how often Tesco put diesel/water/baked beans into their petrol storage tanks is entirely separate.
Identical RON will provide identical power (where an engine has been tuned to accept that grade)
The RON grade is a legalling binding commodity specification (with reference to gasoline delivery)
If you buy a 40.0% supermarket value vodka, it will get you just a drunk, just as quickly as Grey Goose.
You might get a different headache the next day, mind!
cheshire911 Estoril
Posted: Sun Aug 04, 2013 4:01 pm Post subject:
Interesting analogy with the Vodka GT4. If it says 40% w/v or v/v or 70 degree proof then an own brand has to meet that specification. Of course the own brand is not their own make, it has been put into a bottle I suggest by a major distillery.
I use Shell V-Power sometimes in the hope that an occasional tankful will help to keep injectors etc clean with their additives. BVut without eveidence, I am of the view it is just marketing hype. I have been in the medical and pharmaceutical field all of my life and am always sceptical of any of these claims by Shell or others because the one thing they do not have to do which a regulated industry such as pharmaceuticals have to do is provide compelling double-blind placebo-controlled studies in large populations across dimesions of efficacy, safety and tolerability. Hence my cynicism about these marketing claims.
Rest of the time I just use Super Unleaded from wherever or whichever supermarket I can get it from. If anyone knows of any studies with statitically significant methodology about these claims by Shell etc. then I am keen to scrutineer the claims - I have been used to doctors pulling apart clinical trial data and have become an expert at
spotting real data from marketing hype. _________________ 996 2002 X50 Turbo Manual
Posted: Sun Aug 04, 2013 4:09 pm Post subject:
Ive always found a bit of Toluene does the trick now and again, as well as boosting the octane massively. _________________ I came into this world screaming and covered in somebody elses blood! I have no problem leaving the same way!!!
HarryH Montreal
Posted: Mon Aug 05, 2013 9:58 am Post subject:
Interesting.
I run mine on super unleaded because that is what Porsche specify, usually BP or Shell but I'm not obsessive about it. On the odd occasion where I find myself needing fuel and the garage I pull into doesn't carry super, I don't worry about putting a third to half a tank of straight unleaded in there.
Why third to a half? Semi rational explanation would be that it gives me some range, but with the 5-10 litres of super still in the tank, doesn't completely dilute the blend down to 95, and means I will top back up and raise the average again before very long. Or maybe its just irrational.
To be honest I personally have never really noticed an objectively measurable difference, in performance or on the temperature dials, under normal driving conditions. Can't speak to consumption, I don't monitor it that carefully. So I'd say run it on the good stuff, but don't be so dogmatic that you play Russian Roulette over whether you can get to the next Shell garage before being stranded on the side of the road. _________________ 2009 997.2 C2S PDK cabriolet
2004 996.2 Targa Tiptronic S - sold
(Warning - capabilties of car far exceed those of driver)
cheshire911 Estoril
Posted: Mon Aug 05, 2013 11:09 am Post subject: Techron Super Concentrate
Does anybody have a view about these fuel additives such as Techron Concentrate? Are they all they are hyped up to be - cleaning injectors etc.?
Mercedes Benz's reply when I asked about my E-Class 220 Diesel is that MB do not recommend any additive and that for new cars it can invalidate hte warranty.
What about a 10 year 996 Turbo? Would it benefit from this being added once a year into a tank of petrol? _________________ 996 2002 X50 Turbo Manual
Having come from the world of Jap performance cars into the loving arms of German high-performance I can say in my experience that I've never noticed a jot of difference between fuels of the same rating.
Even in highly stressed turbo's I've never been able to discern any difference between Shell/Tesco etc.
I did however own a rather raggedy L registration Cavalier SRI (Redtop with porous head and everything! I was a poor student!!)
The first time I rebuilt it, previous owner had done 50k in it, engine was horrific.
Second time I'd been running it on 95 ron for ~15k and it was once again, filthy.
Third time I'd done another 20k or so but on V-Power back in the day and it was still spotless.
Could have been a fluke but I would put some weight behind the idea of there being additives and detergents in the fuel.
I still don't think it makes a jot of difference to the performance but perhaps there is some weight in the cleaning claims? _________________ 997.1 C4S
GT4 Nordschleife
Posted: Mon Aug 05, 2013 5:43 pm Post subject:
Interesting.
They will all run on 95 RON.
The "hating" it bit is where the engineered fuel stratification will not kick in - ie the engine's key feature is turned off.
Fox Terrier Hockenheim
Joined: 27 Jan 2012 Posts: 684 Location: Bedfordshire
Posted: Mon Aug 05, 2013 6:42 pm Post subject:
A lot of "super" unleaded petrol is rated at 97 RON e.g BP. It says to use 98 on the inside of my fuel cap (997.2).
There's no real difference performance-wise between petrol of the same rating but I use Shell (98 RON) whenever I can because it just seems to work well.
habanero Spa-Francorchamps
Posted: Mon Aug 05, 2013 6:53 pm Post subject:
One thing I will say is there's been a fair amount of negative feedback on Shell's new V-power Nitro.
I've stopped using it for the time being as my car (M3) was hunting at tickover (especially from cold). I have replaced it with Tesco 99 and the car has been perfect. I even went back to Shell and the same thing occurred so back to Tesco I went.
Apparently it's something to do with the cleaning chemicals in the fuel... _________________ 2014 Porsche 991 GT3 CS - 2005 Porsche 997 C2S (wifes) - 2016 Range Rover Autobiography 4.4 - 2013 Maserati Granturismo Sport MC Shift (sold) - 2011 BMW M3 DCT Competition (sold) - 2002 Porsche 911 Turbo (996) 6spd Aero Kit in Polar Silver (sold)
Page 1 of 3
