What's the latest thinking on oil recommendation? Hartech?
Grahaml
10 Aug 2009
124
Sorry in advance - I know these questions come up all the time.
Looking to do oil change in the next week or two.
I am not really interested in other drivers opinions generally and I am sure many are perfectly happy with whatever they use and have never had any trouble with. But can anyone point me to any genuinely authoritative guidance?
I have seen much that recommended changing from Mobil 1, and moving to a 5W40 rather than a 0W40. I had previously gone with Shell Helix 5W40 in my Boxster.
I read that Hartech "are presently using Castrol Magnatec 10W40" but that was in 2012 and they had also said they were working with Millers Oils.
I respect that advice but is this their most recent opinion?
Graham
Re: What's the latest thinking on oil recommendation? Harte
Ring 'em and ask them?
I'm running Magnatec 10w40 semi in my 3.4 996 110k miles. I stuck that in hoping it would be a little quieter for the first second on startup, but doesn't seem to have made much difference.
Previously mine was run on Fuchs 5w40 fully synth for 40k.
I think oil has been debated to death on car forums... I think the usual recommendation is to stick to the stock option unless you have slightly low oil pressure, slight leaks or noises. Then you might try thicker oils depending when the problem occurs (hot or cold).
Thanks - Hartech advised me what they are currently using.
You're spot on Martian.
thanks
When I spoke to Hartech they recommended millers nanodrive 10W50. Which I have put in my 2004 c4s. The engine was smooth before but seems even more so now. The only issue I had with it was the cost of £130 delivered for 10litres.
same here Graham - costly stuff I am finding.
Currently looking at where to get the best prices. Best so far is an ebay trader JJC Race and Rally at £60 for 5L delivered.
It is difficult for anyone to evaluate different oils effectively - but these engines have the potential to suddenly give rise to temperature hot spots (due to various reaction system times, faults and failures). Under normal operating temperatures - if temperatures were equal with a small temperature rise throughout the engine then most high quality oils of the right viscosity range would work well - but it is if and when a sudden hot spot occurs that problems can follow.
One benefit of Nanodrive oil is that it releases the effectiveness of special additives to help lubrication at more elevated temperatures - so if there was a hot spot somewhere in the engine (for any reason) the oil in that location would hold up better than a more standard oil that would just reduce its viscosity and potentially lead to a failure.
I therefore look at it as a kind of failsafe in these rather delicate engines.
So far (touch wood) in one and a half season of racing with several engines) we have experienced no engine failures of any kind during the Porsche Club Championship (which we are leading\) and have only experienced one failure in another event with a driver unfamiliar with the car (not connected in any way to normal racing but due to external influences beyond the engine's control).
We have just stripped three of them for rebuilds before the last 4 race meetings that involve 9 races (as they are all crammed into just 6 weeks), without finding any problems needing attention - fingers crossed - racing always throws up the unexpected and we all live in hope that we can continue with this excellent record - but know anything can happen!
Baz
RPM Technik gave me a 1 litre top-up bottle of Mobil 1 New Life 0W-40 when I bought my 996 Turbo from them. I assume this is what they use for servicing as well.
Surely more regular oil/filter changes to maintain quality lubrication is also worth doing?
The millers nano oil has a lower CST measurement @100C as well as a lower HTHS @150C. Therefore it will give a slight power increase as it's thinner(re less resistance) at higher/normal operating temp. My concern would be that thinner oil cannot actually transfer/absorb engine heat/hotspots as well as say Totals Porsche approved 5w40 which is reported in the USA to help reduce internal engine temps by a few deg's. In engines such as ours, heat management is always a concern, hence I would never personally put nano oil in any of my 911's
Molybdenum disulphide granules in this specific oil does lub well but there are reports of it blocking oil filters towards the end of a 15k/2year service interval(which Porsche approve on the 997 for example). This is in the form a light sludge that coats engine parts. Owners sticking to the 2 year 18k mile service interval may be creating issues for themselves by using nano technology vs those who change engine oil far more regularly with no sludging issues. Clearly a race car gets many oil changes and many have enhanced engine cooling, so issues with nano technology may never occur......but on a road car with a 2 year service interval??
Surely if you have raced these engines(as outlined below) at max revs, meeting after meeting then stripping them down with no issues the word "delicate" is perhaps a tad misleading? In fact, I would suggest that it speaks volumes about the general quality and reliability of the Porsche 911 engine
.....as can engine failures on BMW, VW, SEAT's etc of course but its always encouraging to read about such fantastic reliability reports from a Porsche race team who are working these engines very hard indeed :thumb:
AS GT4 says - no.
I had a Boxster S for 3 and a half years and eventually got round to selling it and bought the 996 in February this year.
It's a 2001 car, 67K miles C4. Although basically sound the PO hadn't used it much (15K miles in 5 years) and it needed a little tidying. I wanted a GT3 look but this car was local to me and I paid a good enough price that I could afford to get the work done (or do it myself) once I'd bought it.
Since I've owned it I have
- Fitted GT3/ Aero kit - fitted at a paintshop I have known and trusted for the past 20 years. At the same time repainted the rear wings which had a couple of little dings and resprayed the bonnet which had a little spot of corrosion starting under the badge.
- replaced all the brake pipes (I didn't spot that when I bought it)
- replaced the exhaust with a system from MilleMiglia (made by Australian company Hi-Tech Mufflers). Bought second hand but unused. Again I didn't realise the original PSE was in such a bad shape
- Fitted a JVC double DIN system with blue-tooth, satnav, reverse camera etc
- 2 new Cont- rear tyres
- 15mm wheel spacers all round
- Low temp thermostat
and in the past two weeks I have ...
- fitted H&R lowered springs
- repainted brake calipers red
- replaced front discs (corrosion on inside as usual)
- home-made (GT4 style) Helmotz Resonator conversion
- replaced exhaust gaskets between cat and manifold
Graham
There are some things you should never do because it seems people take it too personally to be rational and constructive - they are - criticise the way someone else is bringing up their children, argue about politics or religion with friends or it seemed to me from reading previous posts - comment on what oil to use in your car.
Different people have different views and seem to react strongly if anyone else suggests there may be an alternative viewpoint and knowing this I was reluctant to comment on this post except the heading was asking us directly what the latest thinking was and I thought it deserved an answer - which I tried to keep non technical and very general (to avoid conflict) but not sure now if that was worthwhile.
A typical reaction is reproduced below -
bazhart said:
It is difficult for anyone to evaluate different oils effectively - but these engines have the potential to suddenly give rise to temperature hot spots (due to various reaction system times, faults and failures). Under normal operating temperatures - if temperatures were equal with a small temperature rise throughout the engine then most high quality oils of the right viscosity range would work well - but it is if and when a sudden hot spot occurs that problems can follow".
To which the response was - "Surely more regular oil/filter changes to maintain quality lubrication is also worth doing?"
This is like answering the question of if God exists? with "well God says" etc - the response does not relate to the question completely objectively.
I cannot see any connection with what I was quoted as saying about the general position and any suggestion I would promote reducing oil change intervals and of course changing the oil regularly is better - the more often the better too - unless you are getting silly about it. Indeed due to the particles that gradually filter into the oil - and the degredation of additives and the base oil - the high quality oils often only preserve that performance longer than cheaper ones that might be just as good if changed more often.
I have not mentioned this to promote a new argument but just to demonstrate how the reaction to the question about oil choice often has little to do with the original question I answered and really seems to be just posted to demonstrate that the poster knows more about the subject and I am wrong (just like with how to bring up your child, religion or politics) it seems to be taken beyond a normal reasonable discussion to a conflict.
I am not a tribology expert and I think it would be wrong of me to argue on the subject - all I can do (and have) is reproduce what our oil suppliers have explained to me and leave it to the readers to decide what to do.
As I understand it a thinner high quality oil will transfer heat better than a thicker oil (due to anti shear) providing the additives maintain the oil film - but I am not an expert although our results suggest the advantages explained to us were proven.
Another point raised was that "Molybdenum disulphide granules in this specific oil does lub well but there are reports of it blocking oil filters towards the end of a 15k/2year service interval(which Porsche approve on the 997 for example). This is in the form a light sludge that coats engine parts. Owners sticking to the 2 year 18k mile service interval may be creating issues for themselves by using nano technology vs those who change engine oil far more regularly with no sludging issues. Clearly a race car gets many oil changes and many have enhanced engine cooling, so issues with nano technology may never occur......but on a road car with a 2 year service interval?? "
Can I point out that at Hartech we do not recommend 2 year oil changes and (for example) on our Lifetime Maintenance Plan the maximum we allow between changes is 1 year or 12K - despite the fact that for a fixed price maintenance scheme this obviously costs us far more than if we adopted the Porsche recommendations (and we will change at 6K intervals if requested depending on the age and mileage of the particular scheme) so to imply we do not agree with frequent oil changes is completely the opposite of our clear position and totally misleading
Another argument raised was in response to my comment "I therefore look at it as a kind of failsafe in these rather delicate engines" and was as follows.
"Surely if you have raced these engines(as outlined below) at max revs, meeting after meeting then stripping them down with no issues the word "delicate" is perhaps a tad misleading? In fact, I would suggest that it speaks volumes about the general quality and reliability of the Porsche 911 engine"
My response is that the above comment is utter nonsense and it is not because our engine designs and components are bullet proof that they have lasted well in racing - but because of our skill at assembling them, and other measures we took (all allowable) to improve reliability plus the limits we placed on the maximum revs and ignition and fuelling (which we are allowed to change).
Compared to a 993, GT3 or Turbo there are many components in a Boxster S or 996 that have been manufactured cheaper but with less high quality - that result in the general reliability being lower and will result in them being unable to cover the same mileage without rebuilds.
Furthermore - the basic crankshaft design compared to those other models - incorporates a long overhang at the rear end that allows more crankshaft flex and reduces rear main bearing life.
The Open Deck cylinder design also reduces the rigidity of the cylinder roundness and leads to early cracking and piston blow by (compared to those other models that do not incorporate those features).
This is why so many engines are being rebuilt - so what are we arguing about? DOES THIS NOT MAKE THEN RATHER DELICATE?
These issues mean that the engines will not be as reliable for track use or long term high performance aggresive driving. The Boxster S has lower output and piston weight with basically the same engine as a 996 and so does last better but the larger the engine the less strong they are and the shorter their lifespan will be.
Then I said that "So far (touch wood) in one and a half season of racing with several engines) we have experienced no engine failures of any kind during the Porsche Club Championship (which we are leading\) and have only experienced one failure in another event with a driver unfamiliar with the car (not connected in any way to normal racing but due to external influences beyond the engine's control).
We have just stripped three of them for rebuilds before the last 4 race meetings that involve 9 races (as they are all crammed into just 6 weeks), without finding any problems needing attention - fingers crossed - racing always throws up the unexpected and we all live in hope that we can continue with this excellent record - but know anything can happen!"
To which the response was ".....as can engine failures on BMW, VW, SEAT's etc of course but its always encouraging to read about such fantastic reliability reports from a Porsche race team who are working these engines very hard indeed." To which my response is - YES it is encouraging to see that some specialists can overcome the basic weaknesses and get reliability at racing speeds despite them.
These are actually the different engine designs to most Porsche racing engines and I don't think Porsche have raced the M96 or M97 engine range (although I stand to be corrected) - certainly the majority of their own race engines (and the vast majority of those raced for years Worldwide are quite different) and have features, components or design changes that make them more suitable..
I think a reasonable person can see from all this that my simple attempt to offer a low key sensible response to a direct question was broadened out to an argument largely nothing to do with the question and quite misguided in the links and points made that were more posted to start an argument or elevate the status of the post provider than to help answer the question that was anyway directed to us.
Consequently I am not going to waste any more time nit picking over the bones previous or no doubt to follow and hope those requesting my advice understand why and will allow me to decline any more on this subject.
As I already knew before (and should have paid more attention to) it seems that "OIL" is just one of those taboo subjects that generates responses that are too intense and argumentative to justify too considered a response.
Baz.
Mines on the Hartec service plan and as far as i know mine was on castrol .
RSPSTEVE said:
Mines on the Hartec service plan and as far as i know mine was on Castrol Magnatec 10W40 .
I,m doing under 6k pa maybe thats why?
Steve
124,534
1,441,257
48,945
kclassicauto
