motokustom
- Joined
- 21 May 2013
- Messages
- 64
I bet there is a thread somewhere so I apologise if I am opening a covered subject in advance
While recently reading a well known magazine I read that they advocate the use of Mobil One 15w 40 oil as opposed to 0W 40 oil that my local main dealer uses and recommends. Now I confess I do not know what all the listings mean? but I do know it relates to engine heat .... So question is What would or do you use in the UK?
My car has always been serviced prior to my recent purchase by a main dealer and so I assume? it has been the recipient of Mobil One 0W 40 oil. I will be doing some service work myself and most likely will be using an independent from now on as the car is getting on and I feel a good independent is fully capable of keeping it in tip top condition! And at half the cost!
Would there be anything detrimental in changing the oil now? Does a motor get "wedded" to a particular type and viscosity? Am I right in assuming the 0W is runnier than say the 15W? there so easier to start in cold conditions?
I am sure there are others out there who have either been through this dilemma? or are indeed considering this very issue now? I know any information will be of good use to me and I sincerely hope it will be of use to others too.... regards and thanks Dave
