997 : 2004- 60
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayenne : 2003- 7
AeroAnt
PostPosted: Sun Nov 25, 2012 6:39 pm    Post subject: Owned 911 for 2 days before engine problems Reply with quote
Where to start. Sorry for the long post!
Hoping someone can give some advice on normal Porsche procedure and also the likely cause of my problem
Picked up our 997.1 on Monday evening and everything seemed well until Wednesday evening.
After filling up with approx. 20litre of fuel, already had half a tank, about 15 miles i had problems with the revs, it would not rev about approx. 4200 rpm... this was followed by the check engine light. I thought maybe it was just a phantom limp home mode due to the heavy rain(wishful thinking). I pulled into to a petrol station switched the car off and restarted it. No check engine light and everything is running smoothly again, then attempt to accelerate and the same thing happens, very noticeable misfire at approx. 4200rpm massive hesitation i let off and the check engine light comes on.
I call the recovery people who advice unless the check engine light is flashing it is OK to drive back home and they will recover the car in the morning. So that is exactly what i do. RAC/Porsche turn up early morning do some checks and tell me i have codes p0300,p0301,p0302,p0303 and that they would recovery it to my local Porsche. Great i think.
Next day i get a call advising the warranty might be void due to an over rev in range 4. Which apparently is a missed shift. I know categorically i have not missed a shift, i let them know that i have hit the limiter on the way up a few times in 2nd gear but not not missed a shift. According to OPC the only way a Range 4 would come up is if i have downshifted into the wrong gear. I 100% know this hasn't happened. I have driven approx. 260 miles since owning the car of which 200 miles have been relatively gentle motorway miles.
So i am really confused at this point, racking my brain trying to remember if this may have happened without me realising. Check through the forums it would appear a range 4-6 would be a noticeable miss shift. I call them back, but they are saying they have spoken to the head tech and he said the data is 100% accurate and that in order to find out if my warranty is valid i would need to pay for compression/leak down test. They cant give me an exactly time it happened only that it happened after the ran the checks before handover??. Fortunately after speaking to the OPC i bought it from, they agreed to cover the cost for this.
They haven't even given me an indication on what the issues are as they are not prepared to do anything until Porsche check the leak-down and over rev. The OPC i bought it from think that the timing may have slipped based on the information i gave over the phone.
Because all of this was done on Friday, they could not get an answer from Porsche UK. I assume it will be Monday/Tuesday.
My questions are;
How reliable is the over rev data and how do i know it wasn't done before i collected the car? I know that it went to be 'detailed' before i collected it.
With the fact the car runs perfectly fine under 4200rpm, could it simply be a sensor issue cam/air etc?
Has anyone had a similar issue?
How likely is it porsche will refuse a warranty on a car that has been run for 260 miles since purchased from OPC?
The car is OPC bought with 2 years warranty, 45k miles, 55 plate.
spyderman
PostPosted: Sun Nov 25, 2012 6:46 pm    Post subject: Reply with quote
Doesn't the ECU record when the last over-rev occurred?
The dealer needs to be told that they need to prove that you caused the over-rev in order to legally invalidate the warranty. Even if the car wasn't under the Porsche warranty, you have legal grounds to reject the car under the Sale of Goods act. But don't listen to me - get proper legal advice. At the very least, talk to Trading Standards.
2004 Boxster S 550 Spyder Anniversary Edition
Ekona
PostPosted: Sun Nov 25, 2012 6:51 pm    Post subject: Reply with quote
First off, hi!
Your issues sound coil pack related, especially if it happened in heavy rain. No biggie, very common issue, I wouldn't worry too much about it yet.
With regards to the over revs, it is possible for the data to be wrong. In essence, if you only had 1 rev in R4 then that would be impossible, as the engine would have to be in that zone for such an infinitely small amount of time it simply could not happen. Likewise if you had more revs in R4 than in R3, that's also impossible as it would have to go through R3 to get to R4. Basically you'd need to get the numbers for us to have a look at, they will give them to you.
The over revs also tell you when it happened, so if it was after you owned the car then you're stuffed, but if it happened before you took ownership then it's their stuff up and you won't have to pay a dime. You won't be able to renew your warranty either, but that's a couple of years away yet.
Dan
Ex-997.2 C2S PDK
AeroAnt
PostPosted: Sun Nov 25, 2012 7:06 pm    Post subject: Reply with quote
Thanks for the fast replies.
Apparently it records only the operating hours it occurred at? Which seems like it occurred between agreeing the sale and it breaking down. So there is possibility that it occurred while in there hands. Not that i'm suggesting it did until i get more details from them tomorrow. Im not even sure it has happened at all, certainly not in my hands.
I did think Coils/spark or cam sensor etc. What made me worry was that i assume that they would check the codes and have a fairly good idea of what is wrong. I probably wrongfully assumed that if it was simply coil pack or similar that they would be able to rectify this without doing a leak-down test and checking with Porsche UK. But after some discussion with the OPC, it would seem once they get an over-rev flag they 'have' to check with Porsche UK to ensure that they are willing to pay for warranty work no matter how small or big the cost?? I guess that as its not the OPC i bought it from, they are just covering themselves in terms of getting paid.
Its just a bit daunting hearing, in the first instance; 'engine leak down test at your cost' & 'possible non warrantied engine work'. All seems a little OTT if they know its likely to be a sensor or coil-pack.
Tinker
OK, so where's GT4 when you need him?
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Sun Nov 25, 2012 7:09 pm    Post subject: Reply with quote
Dan, I just don't follow your logic wrt number of overrevs in each range. What you are saying is like saying it is impossible for the engine to spend more time in the 3-4k range than in the 2-3k range because it has to pass through it. I agree it is unlikely, but not impossible.
I know on the 996 it tells you the engine run time at which the last one occurred, the garage can use this to show that it happened in the last few hours but not how many of the total events occurred at that point. I.E. 234 total ignition events, last at 567 hours, current run time 567.2 hours.
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Sun Nov 25, 2012 8:33 pm    Post subject: Reply with quote
Your codes are all random misfires on all cylinders of bank 1-3 and I suspect it'll be coil packs getting wet. It could be vario cam issues as I had similar problem with a misfire at 4500 revs and was told it could the vario cam sensors as this is when they start to work. Mine turned out to be a dry connection of the engine wiring loom though.
I seem to remember someone on here getting Warranty even with an over rev after the compression was checked by OPC. So as long as the compression test turns out OK you should be able to renew next time and maybe claim this time.
Ekona
PostPosted: Sun Nov 25, 2012 8:44 pm    Post subject: Reply with quote
Not quite. If the ECU says that you have had 100 in R4, but only 50 in R3 that would be absolutely impossible to achieve. R3 is between 7700 and 7900, R4 is 7900 to 8400. As such the engine must pass through R3 to get to R4, and therefore the engine must spend at least twice as long in the lower range: Once to get there, and once to get back.
Not directly related, but to give a more exact idea on the numbers and length of time spent in these ranges, ths is pinched from Planet9:
So if range 4 is 7900 - 8400rpm and then the engine fired 86 times in that range, that works out to:
86 / 3 (ignition cycles per revolution) = 28.7 engine revolutions
Assuming the average speed of the engine in that range was ~8000rpm, then:
8000rpm = 133.3 revolutions per second
Time spent in range 4 = 28.7 / 133.3 seconds = ~200ms
Dan
Ex-997.2 C2S PDK
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Sun Nov 25, 2012 8:56 pm    Post subject: Reply with quote
Sometimes even though it passes through rev range 3 both ways there is more chance it will sit in R4 a lot longer until the driver realises the engine is making the wrong noises.
Ant Blain
2003 Porsche 996 Carrera 2
PostPosted: Sun Nov 25, 2012 9:03 pm    Post subject: Reply with quote
Unless I'm being thick (quite possible) I agree with MC on this one; yes you have to go through the 7700-7900rpm range once on the way up and once on the way down but you could theoretically spend however much time you like in the 7900-8400rpm range before you come back down through the 7700-7900rpm range.
The only thing that would be impossible is having just 1 ignition in the 7700-7900 range, you would have to have at least two (one revving up, one revving down again) but you could have 20 on the way up, 500 above 7900 then another 20 on the way down couldn't you?
Obviously the big caveat here is that the limiter should stop you revving to that level of rpm (sorry not sure where the limiter is on a 997) but assuming it doesn't, it's perfectly possible to have more rpm in the higher 7900-8400 rev range than in the 7700-7900 range I would have thought...
Dont know
_/_/_/ ex-2003 911 Carrera _/_/_/
AeroAnt
PostPosted: Sun Nov 25, 2012 9:35 pm    Post subject: Reply with quote
I can potentially see how that is possible; If the majority of the over rev was in the top band, and say you keep your foot in it for the duration until you realise that you are banging off the limiter then rapidly allowing the revs to drop could theoretically allow more registered over revs in the upper band than the lower, which it would pass through more quickly. THEORETICALLY. Really i have no idea how these are monitored or registered.
What i don't see as possible is registering a range 4 mechanical over rev without knowing you have done it. Fair enough if i had owned the car for a extended period OR had tracked it, maybe i wouldn't remember. But not 2 days to and from work followed by a trip to the petrol station. Which is why i wonder how accurate the over rev recording is. That is assuming it hadn't been driven before collection
webbo
PostPosted: Sun Nov 25, 2012 10:01 pm    Post subject: Reply with quote
My coil packs gave up in wet weather too, they get hot and crack I'm led to believe, then let moisture in, they ain't expensive, I prayed em with wd40 for a few weeks then replaced em.
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Sun Nov 25, 2012 10:08 pm    Post subject: Reply with quote
You would know if you'd over revved it.
Who knows when OPC did their pre purchase check on the ECU, what work may of been done inbetween, had it been taken out on a test drive by someone else???
Ekona
PostPosted: Mon Nov 26, 2012 7:22 am    Post subject: Reply with quote
Dont know
Right, I see what you guys are getting at now. I agree, however you'd end up with an engine that was damaged straight away and you'd know about it instantly or you'd have spent so long there that, you wouldn't be able to forget as you'd spend the next year worrying about it.
I guess we really need to see the over rev numbers per range here to have a sensible guess at anything else.
Dan
Ex-997.2 C2S PDK
HarryH
PostPosted: Mon Nov 26, 2012 10:31 am    Post subject: Reply with quote
Just to chip in. Lots of cleverer folk than me on here, but from my experience of coil pack failures when they go they go and it manifests itself at all rev ranges from lumpy idle upwards. So if your issue only kicks in above 4k I'd be very surprised if it was coil packs. Hope you get it sorted.
2009 997.2 C2S PDK cabriolet
2004 996.2 Targa Tiptronic S - sold
(Warning - capabilties of car far exceed those of driver)
colt
PostPosted: Mon Nov 26, 2012 2:33 pm    Post subject: ?????????? Reply with quote
Hi all, This is exactly the scenario i have wondered about ,in that for the opc to take that standpoint ,i would have thought that they must give you a print out of the cars data showing overevs and operating hours counter readings ,date and mileage readings more or less just before they hand you the keys?? and i wonder just how diligent they are when accepting a part ex from a customer ,in checking this before they give you a price? Also i wonder if they have ever been caught with a car carrying overrevs which they did not check into at the buying stage and then conveniently forget about when preparing it for there approved used car program, only to sting you with engine health check work come warranty renewal time?????
Like doctors, policeman, solicitors and the like we assume Porsche dealers are all honorable people ,but as time goes by you learn they can be just as unscrupulous as the kerbside motor dealer can be?
I wait with interest as how you get on......
Christian.........
I have advised a good few people to demand to see this data when considering a modern porsche for some time and it's of particular importance if you want to buy a porsche warranty.
AeroAnt
PostPosted: Mon Nov 26, 2012 3:43 pm    Post subject: Reply with quote
Well i have just spoken to them today.
After doing the leak-down test one bank is showing some leakage.
Apparently 2 hours ago there was 7 revolutions in range 4. They did not have the print out to hand only what the technician had written down. They were not willing to send the data via email but happy to show it to me when i go it?
Their view is the timing has slipped and are unsure if there is any damage, but are waiting on Porsche UK to advise on how to proceed in terms of warranty. Their current view, regardless of who is paying is ; the 'leaky' bank will need to be re-timed and then tested.
Im not sure what 7 revolutions equates to in real time?
Still finding it very difficult to believe this has happened and i am assuming that 7 revolutions is an infinitely small amount of time.
Ekona
PostPosted: Mon Nov 26, 2012 3:54 pm    Post subject: Reply with quote
7 revolutions or 7 firings?
If it the former, and assuming an average of 8K rpm, then it's 50ms in R4. If it's 7 firings, then it's 10ms. We are talking absolute fractions of a second here.
Dan
Ex-997.2 C2S PDK
AeroAnt
PostPosted: Mon Nov 26, 2012 4:07 pm    Post subject: Reply with quote
The information wasn't that clear initially he said;
'You have been in range 4, 7 times' To which i replied no way it has to be wrong.
Then he said '7 recorded cycles'.
Im making an assumption, but it seems they record ignitions rather than revolutions... so would assume he means 7 ignitions in that range?
Guess i can't be 100% until i get there for the print out.
AeroAnt
PostPosted: Mon Nov 26, 2012 4:21 pm    Post subject: Reply with quote
They are fairly confident that it was 2 running hours ago.
I'm going to have to accept it happened. Even though 2 running hours ago 100% puts me on a busy M25 doing normal motorway speeds. On top of which i know i haven't driven it hard, due to weather and work, let alone missed a shift.
Regardless of who picks up the bill for me thats the most worrying thing, engine damage may have occurred during my ownership without me realising what i have done.
My previous cars have been driven a LOT harder on the road and track without an issue. Yet a porsche with 45k miles, being driven sedately seems to have slipped its timing or worse during the course of my normal commute.
Goto page 1, 2, 3 ... 14, 15, 16  Next
Page 1 of 16
